Ok thanks for that info.
I agree labeling is not good. I need to go through an sort out what the previous owner's have done. The label on the door is mostly correct but there have been some changes over the years. Yes it takes a lot to cool a 3,000 SF home in Florida. It basically has to run 10 months out of the year and even runs a little bit in those other two months. It has to cycle on and off all day long to keep the house at 74F and deal with humidity. I have a top of the line American Standard system that is only just over a year old so it's about as efficient as possible.
I have zero gas service in my area. I appreciate the other suggestions.
Yes 200 amp main. I've been looking but can't seem to find any GE tandem breakers. I have seen some people use 20A/30A tandems to reduce area but GE doesn't seem to make any of those. My thought is to build a subpanel and move enough of the 20A over to that to install a 50A to the subpanel and a 50A for the 14-50.
I've actually sent that picture to two local electricians. The first one quoted $375 for the 14-50 installed right there next to the panel which is where I need it. The second one which I got off Tesla locator, and who knows it's an outlet for a Tesla, quoted $500. So they must have some idea of what they plan to do with the breakers.
I told the first guy the outlet was for my father to plug in his RV when he visits the grandkids a few times each year lol. Looks like easy way to avoid the Tesla tax.
Yeah, that makes sense if you don't have gas service, and I was wondering if it was a larger house.
I really think you could combine something like the Family room and foyer, and 2 of the bedroom circuits to open up 2 slots. They can just be pigtailed together right in the panel. I did a quick search and couldn't find any tandem GE breakers either, so that's what you'd have to do.
I'd bet that's what the electrician will do too. And $375 isn't too bad really, adds peace of mind that if something happens, your hands are clean.
Looks like Florida is still on 2017 NEC code, so you're lucky that 14-50 won't need a GFCI breaker, that would've added ~$150.
MN is on 2020 code so my inspector had me add them for my welder outlets, but my EVSE trips with it, so I just removed the GFCI and receptacle after final inspection and hard wired it. Meets code as installing per manufacturer instructions can override NEC if it's a UL listed device.
Another way to avoid tesla tax is to just say you want to get a welder and need a 6-50 equipment outlet. You won't have the neutral wire for hooking up an RV, but if you never intend to anyway, no biggie, EVSE's don't need it either. My inspector was the typical old grumpy type and I live in a very conservative area and I assumed he was anti-EV, so that's why I installed the 2 "welder" outlets in the garage. So off chance he got all worked up about EVs and started nitpicking everything I was installing, I was hoping that would squelch that.
Wasn't a total lie though, I do intend to get a 240v welder sometime, my little 120v one is pretty limited, and I use that welder circuit now for a garage heater.
