I believe most systems that draw power get shut down when the traction battery reaches 20% which make good sense; however, if I am not mistaken, the 12V AGM battery will be topped off via the traction battery until the traction battery reaches 0%. After that, the 12V battery will discharge until you can no longer open the doors or drive the car. Would be nice if the car had a way to disconnect the 12V battery negative terminal when the traction battery reached around 5%. This would keep from depleting or destroying the 12V battery and give you maybe enough range to limp home and plug in. To recover when you returned to the car you would connect a 9V battery to the terminals to access the frunk/12V battery and reestablish the 12V battery negative terminal. The method now is to access the 12V battery using a 9V battery, jump the cars 12V battery and drive whatever is available below 0% or tow the car. There is also a very good change the 12V AGM battery will need to be replaced.
We need a solar trickle charger option for this type of problem. Lets tweet@ Elon!
