Maybe loose brake pad?
Discussion in 'Roadster: Technical' started by spaceballs, Jul 20, 2015.
  1. spaceballs
    spaceballs Member
    Sammamish
    #1 spaceballs, Jul 20, 2015
    Anyone encounter this type of noise?
    The noise changes with speed, and if I even tap the breaks very lightly the noise disappears. Sometimes after breaking the noise will stop completely but as soon as I hit a small bump in the road the rattling noise comes back.
  2. djp
    djp Model 3 Performance
    Toronto, Canada
  3. jeremyz
    jeremyz Member
    Thanks for posting that video. I've been having rattling like that in my car for the past couple of months, but I couldn't figure it out. It does sound pretty similar to yours. The thing that threw me off though is that sometimes I hear rattling when I have come to a complete stop. I installed my Carbotech's about 6 months ago. I guess it took them a while to start rattling.
  4. tvuolo
    tvuolo Supporting Member
    Colorado
    I know that sound well. My Carbotechs were quiet until I tracked the car, then they made that same exact sound. I just had to re-goo them.
  5. spaceballs
    spaceballs Member
    Sammamish
    I'm guessing I have Carbotechs as Augkuo was the last owner.
    Nice thanks much for the links!
    Thanks everyone for the feed back! Seems like first thing to do is check out brake pad then.
  6. lmore
    lmore Member
    Trondheim, Norway
    Is this rattle noise only a problem for on the front brake pads?
    Are the brake pad buffer mentioned above really needed?
    I now have the same noise from the front brake pads (at least it sounds like that).
    I particpated when the rear brake pads were installed and we used the "red goo". That was about two years ago, there has been no noise from those. We did not use break pad buffer.
    For the front brake pads, I gave the "red goo" to the guy that were installing (and insisted that he would use it and that brake pad noise was a know problem), but he used his own stuff. That was about a year ago, the rattle started being very noticable last week.
  7. augkuo
    augkuo Member
    Berkeley
    The carbotechs rattle because they're not the same size as the OEM pads - there's the brake goo that you put on to keep them from rattling but a good hard braking should settle them (yes 783 has carbotechs).
