I recently got these tires and they look to small for the time. Michelin 255 45 zr 19 PS4 AS. Has anyone else experiencing this on their MYLR with Gemini rims?
Those are the correct oem size but I do think they look too small too. Some tire installers won’t install them, but you can go with a bit larger 19” tire.
Yes the first number is width (265) and the second number is sidewall (45) and third is obviously the wheel diameter size (19). Use the tire size calculator to see what will fit. I wouldn't go more than 29" overall height of tire.
Here is a handy tool. Plug the stock size in and then plug the new tire size in.
Use our wheel offset calculator to visualize the new tire position when changing wheel and tire sizes. Convert wheel offset and backspacing to calculate the correct setup for your vehicle.
tiresize.com
Wider is fine like I said, up to probably 275. However if you increase both width and sidewall vs stock numbers, it will likely be too big. I would suggest seeing what tires you can find that are available, then also googling to see if others have put those sizes on their Y. "265/45r19 model Y" etc.
