Mirror Not Going Back To Normal position after Autotilt ?
Discussion in 'Model 3: User Interface' started by CanadianMetal, Jan 7, 2020.
  1. CanadianMetal
    CanadianMetal Member
    Vancouver BC
    I have had this issue of the passenger side mirror not going back to original position , and just staying tilted down as I drive .
    Have manually adjusted it back to normal position , but the next day it has same problem.....
    Has anyone else, had this problem ? If so , how did you solve it ?
    Or do I need to make an appointment with the service centre ?
    Perhaps tomorrow I will try toggling auto-tilt off and on again , to see if it corrects its self ...lol
  2. Akikiki
    Akikiki A'-Lo-HA ! y'all
    Kaneohe, HI
    Position both mirrors where you want them, then save your profile.
    Now, put the car in reverse, position both mirrors where you want them to look and save your profile.
    Put the car back in Drive or Park and save your profile.
    Understand now?
  3. CanadianMetal
    Vancouver BC
    OK Thanks, will try that.
    Mirrors seemed fine for many months, as I just started to notice this quirk a month or 2 ago.
  4. badiban
    badiban Member
    Texas
    I have the same problem. I will try Akikiki's suggestion tomorrow. I never set a profile for my reverse position, so maybe that's why. Still seems like a strange bug. Was going to get it serviced, but I suspect it's a software problem rather than a hardware problem.
  5. Petrlol
    Petrlol Member
    Ohio
    Also I've noticed if my wife has driven recently and I get in to drive the mirror isn't quite right.
    If you click your profile again it will finish moving the mirror the rest of the way.
  6. PostalM3
    PostalM3 Member
    Bend
    I just had this problem for the first time in a year of using auto tilt...had to manually adjust while driving, not the best time to be fiddling with the mirror for sure.
  7. Akikiki
    Kaneohe, HI
    I recently helped a new owner that stopped me in a parking lot and asked about her car, not my car. She said she had this problem where when she put the car in Drive, the mirrors tilted down and she didn't like it. "Each time I get in my car to go somewhere the mirrors tilt down and I have to adjust them What's wrong with my mirrors. They won't stay where I put them". Nothing, I said, they are doing what they were designed for. She got in her car and put the car in Drive and the mirrors tilted down. I asked her to adjust them and she did. I said, "Now, save your profile". She did. Then she said, "Stop". I watched as she got out close the door, then opened and got back in. She put the car in Drive and we watched the mirrors. They didn't move. She said, "Oh - I didn't save the profile before". Ta-Daaaa
  8. Akikiki
    Kaneohe, HI
    #8 Akikiki, Jan 8, 2020
    Well, if you decide to manually adjust your mirrors for when you back up, you can hold your foot on the brake while you put the car in reverse to adjust the tilt down. You don't have to find a really big parking lot and drive in reverse while you adjust the mirrors. :)
  9. Az_Rael
    Az_Rael Supporting Member
    Palmdale, CA
    THIS. We have this problem a lot on my car. Took it to service, but they couldn't fix it. Clicking the profile again fixes it 90% of the time. Figure it is a software bug if some sort.
  10. Az_Rael
    Palmdale, CA
    I dont think you understand the issue. It happens when you put the car in Drive. The mirrors dont always fully return from the reverse position. It is intermittent, so not an issue seen all the time. So you end up on the road, then realize your mirror isnt right. Unitl I figured out the retap profile button workaround, I used to have to adjust on the fly too, very annoying.
    It is like the profile setting doesnt complete all the time. Clicking the profile again seems to fix it for me.
  11. Akikiki
    Kaneohe, HI
    I guess I didn't understand that description. I remember we had the stuck mirrors after an update.
    Next time, I recommend you perform a reboot while they are in the wrong position. The likely will not move or correct themselves when rebooting. So, after the reboot, position them and save your profile.
  12. Jree
    Jree Member
    Boston
    I have this problem too, on the latest software.
  13. geometro
    geometro Member
    Austin
    Mine just started doing this. But only for the drivers side mirror.
    any suggestions?
  14. GtiMart
    GtiMart Member
    Quebec City, Canada
    I have that only sometimes, on passenger side. I believe it only happens when I do something special, maybe switch P, R then D relatively quickly. It's been doing this for a long time, multiple months and multiple updates.
  15. badiban
    badiban Member
    Texas
    Ever since the latest update, my passenger side mirror doesn't open up all the way after going into drive.
  16. AdamMacDon
    AdamMacDon Member
    Victoria BC
    This bug happens to me occasionally, I'd say maybe 7-8 times since I got the car 1.5 years ago. I usually just press my profile button again and it puts the mirrors back where they should be. The odd thing I noticed is it usually only happens to one mirror, it can be either the driver or passenger one.
