Eric33432
That is completely normal.So the device can take up to 32A. Essentially what I'm getting is that I will not risk the device getting ruined again running on 13A, so the tesla rep who brought me the replacement charger was wrong. Is it normal that when charging on 13A the voltage (as seen on the screen) occasionally changes to between 226-231 volts? Or is it a sign that the electricity line is having trouble to supply 13A. I will say again, the plug was never too hot to the touch, even after 8+ hours of charging.
It is normal in the US for the voltage coming in from the utility to vary. I see my normal 240 volt service vary from about 233 to 244 volts. But the standard is plus or minus 10%, which is 216 to 264 volts. The usual cause of the variance is the load both on the grid and on a particular service.
Depending on the length of the wire from the utility transformer to your premises, and the length of the wire from your breaker / fuse panel to the receptacle in which the TMC is plugged in to, you might see the voltage drop a bit when the car begins charging. Then, whilst the car is steadily drawing 13, or 32 or whatever amps, when the voltage varies that is either other heavy loads coming on / going off at your premises, or the general condition of your grid as the loading varies over time.
Don't overthink this. The TMC is designed for use up to 32 amps, and many people use it at 32 amps for years without problems.
It is a good idea to check the plug and receptacle from time to time. If it is warm that is OK, but if it feels hot, that usually indicates a problem. What makes charging an EV different from almost any other residential load is that it is on for hours. When I charge my Model X from 10% to 100% at 24 amps (240 volts) this can take better than 15 hours.
