transpondster
23P and 25P info we knew form wk057 already, the real news is 31P in small pack, combining with info form EPA filling it means 80,5*31/46 = 54.25kWh or if we used 78270 Wh END-SOC small would be 52750 Wh
C rate is higher on the 2170s while supercharging, so I'd say that's an improvement.not to be a real improvement over the 18650s.
Elon never said this at all. He simply said they weren't optimizing 2170s for performance, they were optimizing for cost. That's not to say greater performance wasn't a happy side effect.Maximum performance output is lower according to Elon, or at least not an improvement.
Turning electricity to heat with resistive heating is 100% efficient process. So new method can't be more efficient.Very interesting about the lack of a pack heater I wonder what this will do for winter range, since the pack heater would typically use a fair amount of power at the beginning of a winter trip.
It can if you were wasting heat before. See heat pumps.Turning electricity to heat with resistor is 100% efficient process. So new method can't be more efficient.
Could you be more specific, please. I know how heat pumps work, but Electrek's article doesn't mention heat pumps, only creating heat with electric motor, which has to be resistive process.It can if you were wasting heat before. See heat pumps.
You have to compare the energy use of the dedicated pack heater to the energy used by the power train. I would have thought the dedicated heater would be more efficient, but that’s just a guess. You do save by not having to haul the extra weight of the heater all the time, even when not in use. So even if the power train method of heating is less efficient, you would get longer range when it’s warm.
Edit - I was assuming preheating before you start driving, but re-reading your post I’m thinking you meant that the heater would be running while driving, in which case the power train would be running anyway and using the waste heat would be pure gain.
It Tesla would use heat pump, that would of course be more efficient that resistance heating.
I got the sense (maybe wrong) that most of the heat was generated through internal resistance in the pack itself? That would be just as efficient as resistive heating. If additional heat generated in the motor / power pack could be recycled back via the cooling system, then that could potentially be pretty efficient overall.
Elon mentioned they weren't moving S/X to 2170s right away because he still wants to sell S/X and he's worried about supply issues for the Model 3. (give it a year)
If it has lower internal resistance the generation of heat has a different profile.Sure... but WHY would better performance be a side effect? The ratio of surface area to mass drops, and so you can't get the heat out as quickly. And I imagine that that's one of the factors that limits performance.
Debatable I guess, but in the video you posted we do see what percentage it reaches at the 30 minute mark and if Tesla's numbers (for range and miles/30 min) are to be believed then it's a 7.5% improvement.C-rate is still debatable, and if it really improved then only very slightly.
In case anyone is curious, here's the general layout of a Tesla heat management system:
The short of it is, this system allows the vehicle to shunt heat as needed from any part of the vehicle to any other, or to radiate it away. .
yes, supposedly the patent is different than what's in the car per the car diagram.Isn't cabin heating only resistive? Meaning that car cant use waste heat from motors to cabin heating?
We know it's a new chemistry though from comments of JB and Elon. Tesla has been working on it since 2014.Which would only be possible with an improved chemistry; improved enough so that the drop in internal resistance is enough to offset the added heat removal challenge.
If their priority is $/kwh and reliability/durability, then it further stands to reason that they wouldn't be taking any risks on a significantly new chemistry.
100 * ((170mi / 310 mi) / 0.51 - 1) = 7.5
