(moderator note)
After discussion and agreement, split this off into its own thread
Apologies to the OP for hacking his thread, but thought I would share my experience for those interested in this type of light kit.
I’ve had mine for a few weeks and really like it. Tried a few different kits and experimented/practiced with the installation a few times before finally being satisfied with the end result. Photos attached below, but first a few observations….
1. The first kit I tried was from Basenor (on Amazon). Not very good. For whatever reason, I could not get the supplied light tube to straighten out, even when heated with a hair dryer and stretched out overnight. As a result, the light tube never looked very straight when installed. Disclaimer: I’m a perfectionist. So, what would be acceptable to 95% of the population, I would probably reject.
Also, the brightness of the light tube was not very uniform across the length of the tube. I don’t know if it was the quality of the light tube or quality of the controller/driver that was the culprit. I returned the kit.
2. The second kit I tried was from Nestour (Amazon). Their light tube was definitely better condition/quality. I still had to use a hair dryer to heat/stretch/straighten the tube to my liking, but I think that is probably necessary with all these kits since the tubes are always tied in loops when they are packaged/shipped. The brightness was also a lot more uniform across the entire length of the tube, especially on the long dashboard strip. So, I think both the light tube and controller are better on the Nestour kit. Only negative was the supplied double-sided tape (to attach the light tube to the underside of the dashboard). Even after prepping/cleaning the mounting surface of the dashboard with rubbing alcohol and applying heat (hair dryer), the light tube still did not adhere very well. I ended up buying a small roll of 3M VHB 4905 tape and re-installed the dashboard light tube. This time, I also prepped the surface with 3M adhesion promoter. Bingo! Adhesion remains solid, even during the colder fall evenings/temps. Link to product: https://www.amazon.com/gp/product/B0937C9DJW/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
This particular kit also came with the two matching front footwell lights. However, I chose not to install these because they were too much/bright for my taste.
3. At night, there is some reflection off the windshield from the dashboard light tube, but certainly nothing dangerous or distracting (even when the light tube is set at full brightness). Naturally, it depends on which color you have on, because certain colors are brighter than others (the preset White is much brighter than the preset Red). Of course, if you find it distracting, you can always lower the brightness to a point where there will be zero reflections.
4. I always leave the light tubes ON. Very little power draw with these LED kits. And, as stated by the OP, the light tubes will turn themselves OFF when your vehicle goes to sleep. When your vehicle wakes up, the light tubes will turn ON automatically. Easy, no fuss. Another reason I like leaving them ON… it’s cool to see the lights when you return to your vehicle while out running errands. Note: for those of you who park on the street overnight (or in an area where sentry mode is always on), then you might want to turn OFF the light tubes when you park/leave your vehicle for the evening. You can do this manually (by pressing the power button on the controller) or with the app on your phone.
5. Installation tip: Install the dashboard tube with your head/eyes above the dashboard. In other words, don’t sit in the front seat when installing the dashboard light tube. From the position/angle of the front seat, it will be extremely difficult to get the light tube perfectly straight/consistent across the entire dashboard. Your install may look good/straight when viewed from the front seats, but as soon as you look at the dashboard light from the outside (front fender area of) the vehicle, you’ll probably notice your install was not very straight/smooth and a little wavy. Why care what the dashboard light looks like from the outside? Well, that is the way/angle that everyone else will see it when they walk up to your vehicle or when you are beside someone at a stop light. So, I think it’s important to get the dashboard light tube as straight/smooth as possible, so it looks like a pro installed it. So, installing it with your head above the dashboard will allow you to use the front edge/lip of the dashboard as a guide... This will allow you to line up the light tube properly.
And now for some photos….
