Just an update, I finally got the center console part removed, and I'll save some people some time here, you likely do not need or even want to remove the center console entirely on a 2021+ model if you plan on installing the SUMK kit. What you will want to do is trim down some the thin plastic part ever so slightly just for the corners, as that will not be able to "fit" into the trim with the full height. To explain in words, I cut just about where the wire is, then used a box cutter to trim out along the "wire" line, I did about a 1.5" section where each "bend" occurs. Doing so let it fit very flush and tightly with the trim without looking off.
Another note, as GreenHokie mentioned before, you will need to trim the plastic protection off the SUMK lines a bit as the light emitters get really hot and the plastic part which is a mix of what feels like heatshrink and hard plastic will melt and look dull, trimming off each end of the fiber tube to just expose about 5mm or so of bare inner "tube" will give you great results. Don't skip this step, you will regret it. I would also recommend getting some decent quality electrical tape, I used some cheap stuff to block off 2 of the emitters until I install my dash (will require splicing/soldering), and it's borderline melted already!
The kit I have to install the dashboard lights has not arrived yet so I am waiting on that before I install, curious if someone has some detailed images of the path they took from rear center console to dash and what trim the wires were run under before I get started, but it looks pretty simple. Splicing the cable went fine, but in retrospect I think even 26 or 28awg 4 conductor cables would have worked just fine for this (24awg is slightly thicker than the stock cable).
