Another tip regarding the light strip from AliExpress that you will be using on the dashboard.
1. Slide/remove the pre-applied & pre-shrunk tube from the end of the light strip.
2. Cut away & discard some of that pre-shrunk tube.
3. Slide the trimmed pre-shrunk tube back on the end of the light strip. At this point, you may want to gently hit this area with a heat gun to get a little more shrinkage from the rubber tube to make the fitting more secure/tight.
A combined photo is attached below to demonstrate what I said in step 1,2,3.
I did this to maximize the light that you will see at each end, once everything is installed and lit up.
Note, the last photo shows that I also added a smaller diameter shrink tube to cover the inner core/light tube.
