Model 3 LR RWD driving on highway rearend feel like wobbling side to side
Discussion in 'Model 3: Driving Dynamics' started by BezosBlue, Jul 29, 2018.
  1. BezosBlue
    BezosBlue Member
    houston
    Hi
    I just took delivery of the model 3 LR RWD last Tuesday.
    While I enjoy it, I did notice that on certain area of highway. When speed is over 65mph, I feel its rear end wobble side to side. I don't know if this describe it correctly but it almost feel like you have strong wind from the side which cause the driving feel like this.
    It doesn't happen all the time, but I cannot decide if it only happen on that area of the highway or any random area for now.
    I'm sure there was no wind when it happened.
    Anyone have the same experience? This issue is hard to duplicate to show to the service center.
  2. Inside
    Inside Member
    United States
    Just as a test... try dropping your tire pressure about 3 PSI in all 4 tires.
  3. vijayl
    vijayl Member
    Fremont, CA
    You use your blinkers while changing lanes and you will be alright.. This is because, your lane-change warning is on and if you don't turn your blinkers on, the steering wheels give a subtle feedback.
  4. BezosBlue
    BezosBlue Member
    houston
    I will test it out. It feels like it is mainly due to the road condition.
    On my daily commute, I am not getting the same feeling.
  5. BezosBlue
    BezosBlue Member
    houston
    It happened when I am driving in my lane. I know what lane keeping is.
  6. Westlake
    Westlake New Member
    Houston, TX
    @BezosBlue, I see that you're in Houston. I've experienced this consistently on the new section of 290 up near the Grand Parkway with grooved concrete.The first time it happened, passengers got nauseous and we pulled off the road...genuinely thought something was seriously wrong with the car. I've seen it on the same stretch of road as slow as 40mph and as high as 80mph. Lane departure warning is disabled. We have the sport wheels. Tires originally at 46psi, currently at 38psi. No difference. Next time I'm on that stretch I'll do a bug report.
  7. gilscales
    gilscales Active Member
    Long Beach, CA
    If it is a concrete frwy. with the saw cut rain grooves then I get this all the time in certain areas as the the car tends to follow the groves and I feel it as the whole car wobbling slightly side to side, I've had this happen at a certain area of the 605 frwy here in So Cal in almost all of my previous cars
  8. Pegasits
    Pegasits New Member
    Hopkins, MN
    Same here in Minneapolis on 394 west of downtown, grooved. All cars I’ve had do this but not to this extreme as in my model 3. I wonder if alignment would fix this.
  9. WilliamG
    WilliamG Active Member
    Seattle, WA
    Likely tires. Here in Seattle, driving across SR99 I would have CRAZY wobbling left and right on the siped concrete in my Golf R with Conti 5P tires. Thankfully in my P3D+ with the Michelins I don’t have that issue. But to me it’s likely just tires. Some are better than others at handling this situation.
  10. Msjulie
    Msjulie Active Member
    San Fran Bay Area
    It's called tramlining and it can also effect steering feel in a disconcerting way.. some tires accentuate the feeling too, to add to the fun...
  11. WilliamG
    Seattle, WA
    That’s right. Tramlining. It can be mega annoying, and some tires are WAY worse than others.
  12. Pegasits
    Pegasits New Member
    Hopkins, MN
    camber 0 and toe 0 is what I've seen in another forum (my Michelins are brand new in the box! just bought model 3 6/8/2019!). In the old days, the mechanics would align the wheels IMperfectly partly for this tramlining and partly just to keep the wheels "bound" for general stability and less wear. Mechanics today have likely been pressured to make vehicles fuel efficient - therefore the zeroes - plus they don't want to be caught w/ imperfect camber/toe on their work.
  13. Kappelan
    Kappelan Member
    Greater Toronto Area
    I've experienced the same yesterday and today on our 407etr highway. But only on the certain part of the highway. The concrete part I think and it gets really wobbly, like a strong wind blowing.
    It's totally fine on the regular asphalt-covered highways.
  14. KenC
    KenC Active Member
    Maine
    Yep, grooved concrete, it's a kind of tramlining.
  15. BR666T
    BR666T Member
    British Columbia
    It isn't only on concrete. I experience this consistently at speeds over 120 km/h, and I never drive on concrete. I never felt the "swaying" sensation in other cars on the same roads.
    Like other posters, I thought there was a strong crosswind on my first highway drive. Disconcerting.
    I thought it also may be because of the 225/45R18 Michelin X-Ice 3 tires I had installed - they are narrower than stock and therefore will be better in the snow. The narrower tires may exacerbate the problem, but it sounds like it happens with stock tires as well.
    I plan to drive a friend's RWD M3 with stock size tires to compare (mine's an AWD).
