I recently traded in my 2018 Model 3 Dual Motor Long Range so I have the following parts for sale that are in great condition. Meet up at the In ‘N Out Burger on Cochrane Road in Morgan Hill CA or the Wells Fargo Bank on Blossom Hill Road in San Jose CA nearby Oakridge Mall. First come, first serve, no delivery/shipping, and Venmo preferred. Entire lot for $2,000.00. I don’t have much experience in selling car parts so please let me know if you have any questions. Thanks for looking!
Used 2020 20” Model 3 Performance Gray Wheels - $2,100.00
These wheels are almost mint. Ride quality compared to Aero’s are noticeably different, but not too harsh. These should mount right onto all Model 3’s, but please check for your year. Performance and non-Performance have the same bolt pattern, but the center hub is slightly different. Both trims have a 64.1mm center hub, but the Performance Package has a 2.25 mm step lip that goes out 3mm to accommodate the bigger Performance brakes. For non-Performance doesn't matter since there’s no step lip, but it would the other way around for aftermarket wheels. There's a good picture of the step lip and CAD explaining the hub dimensions here: Aftermarket wheels on AWD Performance Model with performance upgrade
Purchased from the Tesla Shop in 2019. These are in great condition and should fit all Model 3’s (we can always do a test fit). They have no cracks, tears, or any damage whatsoever. These have been discontinued and replaced with the current All Weather Floormats with the high edged lip.
Used in the rear, these will make your wheels flush with the fenders.
This is a great easy to use rack. Slightly bows in the middle and had a little bit of rust dust inside the tubes, which are known issues. Still securely holds wheels.
- ~13K total miles: 2020 Model 3 Performance take offs for 10K miles then on a 2018 Model 3 Dual Motor Long Range for ~3K miles.
- Original TPMS set included.
- 20X8.5 square, original 235/35/20 Michelin Pilot Sport 4S tires [5/32nds (2), 6/32nds (2)], and original set of 20 wheel nuts.
- Hubcentric.
- Inner wheel lips have small rock chips.
- Missing two valve stem caps.
- White plastic showing on the edges of some of the wheel caps.
- Has been washed and stored in the garage since late March.
- Used for two years in normal driving conditions except for once in a Tahoe snow storm.
- Edges are slightly raised, but not as high as the current version.
- Has been washed and stored in the garage since late February.
- Thickness: 20mm; Bolt Pattern: 5x114.3; Center Bore: 64.1mm.
- Used on the above-mentioned wheels.
- Has leftover anti seize grease.
- BLOXSPORT site: BLOXSPORT 6061T6 5x114.3 64.1 for Tesla Model 3 perfermance [BLM Series] - $105.00 : BLOXsport Wheel Spacers, Aluminun 7075-T6 Forged!
- Hubcentric so they’re made for the Model 3 Performance.
- Used for three months to store a Model 3 Aero Wheel set.
- Adjustable to 32" or 48".
- Powder coated gray.
- Max capacity is 300lbs; Aero Wheel set (with tires) is about 140lbs.
- Foldable for space savings.
- Includes the six mounting bolts, instructions, and Allen key.
- Amazon listing: https://www.amazon.com/gp/product/B01I2CHTEW/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
