I will be testing this very shortly, direct test against a 2019 model. In different conditions.
So if the range is not increased due to the updated battery, how is it justified?
As usual Electrek misses the point.
Unsurprisingly, the battery has the potential to be unlocked - but note that the 353 rated miles on the 2021 AWD was achieved with LESS energy than the 2020 vehicles! (See prior post.)
This means 2021 really will have tons of range in the US once all the extra energy is made available. I predict about 370 rated miles.
This info is all publicly available - see above.
I guess that makes sense from a standardization perspective, but I haven't figured out the advantage of the BLE sensors.So it looks like 2021 Model 3 is adopting the Model Y BLE TPMS sensors.
For those unaware, the Bluetooth Model Y TPMS sensors are not available aftermarket. They're currently only available from Tesla and are $75 each or $300 for a set. I just bought a set of the old TPMS sensors for $80 on Amazon.
It could be that some got the cut with a bigger battery and some didn't and were develiered with the old one, so that will only be conclusive if the capacity reported is higher.
SMT ?
Can you lay this out plainly?
Cost savings most likely. I think the 433 MHz TPMS are patented by Continental or something, so probably pricey.
More than just the wheel sensors, the 433 MHz has 4 receivers, one in each wheel well. And all of the wiring to all of the receivers they can skip. Using Bluetooth they can use the built in Bluetooth modem and skip the receivers and wiring.You’ll have to explain this to me since they appear to be 3x the cost. Or are you saying they are both cheaper and Tesla is making a money grab? Or are the aftermarket TPMS you can purchase violating the patent somehow, so are cheaper?
The EPA docs I saw show both 2020 Models (Y&3) with 480 kg battery packs with energy density of 150 watt-hrs/kg. Both 2021 Models also show 480 kg battery packs with 165 watt-hrs/kg. Not sure how accurate their documentation might be, but does reflect a 10% boost in energy density.
Tesla didn't confirm anything. Electrek just posted a german paperwork which lists 82kWh, but in that same thread there is one with 77kWh, 2021 model. Could be a glitch in the papers, but def no confirmation from " Tesla"
This will all depend on avg speed. I would say in highway speed it could be lower and in city, cold weather set to Auto higher. But I never drive on Auto in the winter, because the car uses the AC on Auto, hence my consumption in the winter is not that much higher than summer.Model 3s to be more efficient than pre-pump ones by around 10%, plus or minus a few per cent (in cold weather of course).
Why would the heat pump equipped car be less efficient than a non-heat pump equipped car at highway speed, or have I misunderstood?This will all depend on avg speed. I would say in highway speed it could be lower and in city, cold weather set to Auto higher. But I never drive on Auto in the winter, because the car uses the AC on Auto, hence my consumption in the winter is not that much higher than summer.
I do as well. Before I got the sensors I checked with the local SC parts guy and he said they listed the same sensors for 2021 as 2020. We need a 2021 VIN for the parts guy to know for 100% what sensors they are using.Damn it, I have a set of winter tires for my 2021 P3 waiting in the garage with the old sensors.
misunderstood. I meant that at highway speed the difference between no heat pump vs heat pump is minimal, because the car is warm and it travels at high speeds. I would assume the dif here will be not more than 5%-10%. The main advantage is in stop and go city traffic on short distances with cold car.Why would the heat pump equipped car be less efficient than a non-heat pump equipped car at highway speed, or have I misunderstood?
