EcoHeliGuy
This isn't the forum or threes for this discussion. I only stated that the pure EV's are at a disadvantage in the picture because Hybrids are using the chargers at a parkade. Often I see plug-in hybrids in EV spaces not even charging which is the worst ICEing move possible. If I was a Leaf owner I would be pretty pissed to see multiple hybrids sitting in stalls that I needed to utilize to get home.Well, if we are going to get technical, the 1st generation Volt is actually an Extended Range EV. Just like the BMW i3 REX. The gas engine doesn't actually drive the wheels, just provides power to the electric motor when the battery is depleted. A generator essentially. 2nd gen Volt works a bit differently and is closer to a plug in hybrid.
Hybrids power the wheels with both gas and electric.
But the first and second Gen volt does have a mechanical connection from the engine to the wheels when traveling at highway speeds and efficiency warrants. And if a car has two different energy sources it's a hybrid. They are either primarily gas or electric. With the other source assisting.
