Model S “Drive Stalk” Ambiguous Nomenclature
Instruction words for FSD 2024.2.3.15 “to use FSD, pull drive stalk down once”!
Which drive stalk on 2020 Model S, right or left. Ie
Right stalk = selector of drive direction
Left stalk = FSD
NOTE: control of FSD ORIGINALLY had instruction for four directions.
Toward driver along axis of steering column = on
Away from driver/down direction of column = off
Up toward windshield = increase speed target
Down toward seat = decrease speed target.
Mmm - does this instruction change anything?
You can only engage FSD by pulling the left lower stalk once. You cannot engage autopilot without going in and disabling FSD. Also, the auto speed control is a joke right now, so you may want to disable that until it gets some more work. Everyone will be honking at you. I don't know if it was this release, or a problem with my car, but the regenerative braking is almost non-existent, I checked and it is set to standard. No yellow dots limitations. Warmer here.
