yes that sounds about rightI have a loaner from Tesla, 2018 Model S and set the charge to 90% and got 227 miles of range. Does that sound about right? Im just wondring because my model 3 long range gets 277 at 90%.
I have a 2013 rwd with the 75 kwh pack and i get 220 to 222 at 90%
I thought my model 3 had a 75 KWh battery in it that’s why I was a little confused when I charge to 90%
Many things affect range above and beyond the size of the battery. A VW Passat and a Ford F-150 each have 18 gallon fuel tanks but vastly different ranges when full.
there not going to be the same because of the motor used along with the overall weight of the car.
The M uses a induction motor, while the M3 uses a more efficient yet weaker Permanent Magnet motor.
Exactly and different motors then S and X also.Oh ok I get it, so my 3 is a 75 kWh battery but because of the weight and motor I get more range.
Yeah, see, the Model 3 isn't a REAL Tesla, because it doesn't have an AC induction motor.... *runs*
J/K! I still wave at Model 3s!
Your 3 doesn’t have the same battery as the S either.Oh ok I get it, so my 3 is a 75 kWh battery but because of the weight and motor I get more range.
The cells in Model 3 are a different size than in Model S and Model X, which have cells known as “18 650” (18mm in diameter and 65mm long), while Model 3 has larger cells called “21 70” (21mm in diameter and 70mm long)”.please elaborate for the OP
In addition to those differences, the Model 3 has considerably less aerodynamic drag — both a lower drag coefficient and smaller frontal area. This makes it more efficient at highway speeds and some of that is reflected in the EPA mileage used to rate range.Oh ok I get it, so my 3 is a 75 kWh battery but because of the weight and motor I get more range.
Tesla Model 3: Exclusive first look at Tesla’s new battery pack architecture
