SSedan
Not that it applies in TX but higher amperage is nice in winter when energy use spikes. I can go to work get home set amperage high and recoup the miles quickly before leaving for a trip.
First winter I had the car was on a 14-30 outlet and morning warmups would suck down a few miles even while plugged in.
With 80 amps available I can use scheduled departure and have good regen when leaving even in the cold.
No doubt 40amps is almost always enough, the cost of wire and a wall connector to upgrade to 80 though really is not that much and the one time you need it you will be glad you have it.
My most common road trip involves a 180mile stretch from the supercharger to home. It is nice to put 30miles into the car while unloading and then run to the grocery store, rather than wait to charge higher at the supercharger.
Another angle I think being dismissed is the dual charger cars are very likely already or going to suffer from severe supercharging speed reductions, and likely down to under 240miles on 100%. If you have 80amps available at home you can care less about trying to get home with 20% or something because now you know you can recoup faster.
I fail to grasp the "logic" behind buying a needlessly expensive car like a Tesla then worrying about a one time cost of a few hundred extra dollars to be able to get the most out of it.
If that few hundred dollars is so important buy a lightly used Impala they are cheap, more reliable, comfortable and once you consider repairs and insurance definitely cheaper to own.
