Model S (Performance edition) 1/4 mile time
Discussion in 'Model S' started by William3, Mar 7, 2012.
Tags:
  1. rabar10
    rabar10 Model 3 >> Focus Electric
    Indianapolis, IN
    These two slips really tell the story of EV drag-racing, at least for Tesla EVs.
    Up through the first 330 feet (1/16mi), the two runs are nearly identical (0.1% time difference). This track section is completely torque-limited for the Roadster.
    At the 1/8mi, the times are still very close (0.3% difference) but the slip on the right is almost one MPH faster (0.9%) at that point. Then by the end of the 1/4 mile, we have the final times different by 0.07 sec (0.5-0.6%) and speed different by 1.7MPH (1.6%).
    Note that the earlier slip had the best time, and the runs are only 6 minutes apart. The car certainly wasn't recharged between runs.
    So ignoring other differences like real-time wind speeds, steering corrections, etc., when the car is under full acceleration and gets up into speeds where it becomes limited by battery current instead of motor current, the slightly lower battery voltage in the second run reduced the max power of the car by just a bit in the last half to three-quarters of the track.
    Tesla EVs are perfect for bracket racing. So smooth, consistent and predictable.
    Requisite Model S prediction: 13.88
  2. Dan5
    Dan5 Member
    Delran, NJ
    Yeah, reaction time is what I would like to know, that way I know the "level" of the driver, at least on normal cars it's kind of a good qualifier to determine the quality of the driver for drag racing. A very good driver will have a great reaction time which means he/she knows how to drive the car correctly for the 1/4 mile.
    The first time I took my car to the track, I did 15's, the car was capable of mid 12's, I've witnessed it going mid 12's- I've gotten better, but have yet to break 13.0.
    Point is you need that to determine the who was driving and if they were perfectly pushing the car to the maximum performance. Driving a car perfectly for 1/4 mile is a difficult task, no fishtailing, perfect track, no spin outs, not just completely flooring it, no hesitation, it slips for a split second and your time is screwed up- it's an art form, that's why my gut says the roadster is capable of 12.6 or less
  3. Robert.Boston
    Robert.Boston Model S VIN P01536
    Portland, Maine, USA
    Color me ignorant, but with a Roadster (or a Model S), why isn't the correct strategy to floor the accelerator throughout? The TC will ensure that the wheels never slip.
  4. smorgasbord
    smorgasbord Active Member
    SF Bay Area
    A'Yup.
  5. vfx
    vfx Well-Known Member
    CA CA
    Better than human. Even the Stig?
  6. TEG
    TEG TMC Moderator
    That is what was being done on those 1/4 miles runs I posted.
    As was said, the Roadster is awesome for "bracket racing" as it is easy to get quite consistent times from run to run. ("So easy almost anyone could do it.")
    Some time difference can be had by other factors, such as lighter weight driver, folding back the rear view mirrors, etc.
    The real differentiator is launch technique... Reaction time - brake/accel pedal transition.
    Is the best way to go with traction control turned off (although "off" is supposedly not 100% off), and hold the brake pedal and accel pedal both down at the same time, then release the brake when the "tree" light goes green? I heard some debate as to the best pedal technique for best launch.
  7. qwk
    qwk Model S P2681
    Reaction time doesn't matter, and rarely tells you what the driver is capable of. While It's harder to get the best times out of a stick shift car, the roadster has only one gear. Unless you screw up the launch(hard to do), your only other variables are battery temp, state of charge, t/c on/off. With that being said, I agree that a better time is possible, but it will probably take some tweaking like altering the gear ration through taller tires etc.
  8. smorgasbord
    SF Bay Area
    If you can be rolling just slightly forward, then I'll bet the best is to be in neutral, hold the accelerator down, and simply punch the "D" button (v2.0 & later). I guess that's called a rolling start, but you can be moving even less then 0.5 MPH I believe. It won't work if you're stationary.
    When I take people for rides I do a California Sushi stop, go into neutral and press the accelerator down. Then I ask the passenger to hit the "D" button. It's alot of fun.
  9. cinergi
    cinergi Active Member
    MA
    Without doing the math, I feel like we're seriously under-estimating the Model S. While the sport is 4.4s 0-60 and 4,000 lbs (theoretically), it has *WAY* more power than the Roadster (which will be a huge bonus above 60 MPH).
  10. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Will it switch to D if you're not holding down the brake?
  11. spatterso911
    spatterso911 P100DL - Raven
    Rancho Cucamonga, CA
    do we know how the traction control is set up on the S? Is there a different TC logic for the Perf? My M5 has 3 settings, On, Partial TC, and off. Even with the relatively low torque and slow onset of max torque for the M5, it is ill advised to floor it with TC off, as the rear end can go loose and ruin your run. This car has max torque at go, so I wonder if they would ever give us an option to completely kill the TC.
  12. TEG
    TEG TMC Moderator
    #32 TEG, Mar 8, 2012
    With the Roadster at least, it seems like Tesla designed in some amount of tire preservation and "gentleman's sports car" behavior where it really doesn't want to wildly spin and smoke the tires even with TC in the 'off' position. The one speed gearbox doesn't multiply torque the way something like the M5 would. In exchange for seamless power delivery (no shifting) you have to give up some of that "beastly" behavior you can find in some other supercars.
  13. spatterso911
    Is there a reasonably accurate idea of the torque on the S Performance? or the S (85)? I wonder if there is a power curve plotted out somewhere ...
  14. ggr
    ggr Roadster R80 537, SigS P85 29, M3P 80k
    San Diego, CA
    Yeah. You need the brake to get out of P, but you can switch from R to D with no brake, even while rolling slowly backward. If you're rolling too fast you get an error message "Unsafe transition denied". Make sure it actually switches before flooring it!
  15. Doug_G
    Ottawa, Canada
    Interesting... will have to tinker with that.
  16. smorgasbord
    SF Bay Area
    U
    No need to, at least going from Neutral to Drive - that's the whole fun of it.
  17. TEG
    TEG TMC Moderator
    LOL... So 'matter of fact' and technical... Part of me wishes it said something like "Don't be an idiot", "The car will break if you do that!", or "Abort! Abort! Danger Will Robinson!"
    Well, OK, more like "Reverse speed too fast to change into Drive..."
    I guess they have limited space for error messages, so have to be creative with the short wording.
  18. brianman
    brianman Burrito Founder
    "I'm sorry, Dave. I won't do that, you retard."
  19. ggr
    San Diego, CA
    Yes, I agree; I meant switching from R to D or vice versa.
  20. GSP
    GSP Member
    I am not an expert, but if I recall correctly skidpad G results are almost completely determined by the tires selected, as long as the chassis is at least reasonably well set up. So I am not expecting anything out of the ordinary for the Model S.
    However, the low Cg will make actual driving extraordinary, with very little body lean in corners, also low squat and dive when accelerating and braking. The test results most affected should be slalom speeds and emergency lane change maneuvers. Actual everyday driving will be much more impressive than the numbers, making the "EV grin" even larger - as hard as that is to imagine! :)
    GSP
