Love this car. I don't drive it on dirt roads and only hand wash. My rear quarter panels are getting chipped. Looks like the New flare out is catching the road debris. Anyone else seeing this on their car? only 800 miles
his?
The precut always looks bad because a good film is tucked under the panel where there are gaps, but precuts always end short of the gap. The untucked precut edge starts to collect dirt and begins to lift.
if you look at their options you can click and select "wrap edges" so they will add material so you can do that. Everyone starts from precut patterns created by Xpel and modify them from there.
Mine came with PPF on the passenger side and no PPF on the driver sideMine also came with a piece of film to that area.
But I had it removed when I did PPF to the whole car for a cleaner look.
I made PPF using the same size/model as the original Tesla one. Can you email me at [email protected] to discuss what exactly you have in mind, I can easily do itHas anyone found template cut PPF sufficiently larger than the stock bits on the leading edge of the rear fenders? I'd like to swap the stock stuff out for something that will keep the rocks off the area just above the OEM bits Tesla put on the car.
Okay I will do the model for this, test it and all and release it on my store in a day or two. Will let you know when I have itThe piece you show in the link but going up almost to the top of the fender to keep that little bit of forward facing fender from getting chipped up. Maybe 5 inches or so higher and narrowing the whole time if that makes sense. I just cut a piece and added it above the original Tesla piece. I also put a 6 inch long rectangle on to cover the forward facing part of the rocker panel just below as it was getting chipped up.
So, was your idea for something like this? (in terms of size/fitment... needless to say some refinements are still in order)The piece you show in the link but going up almost to the top of the fender to keep that little bit of forward facing fender from getting chipped up. Maybe 5 inches or so higher and narrowing the whole time if that makes sense. I just cut a piece and added it above the original Tesla piece. I also put a 6 inch long rectangle on to cover the forward facing part of the rocker panel just below as it was getting chipped up.
Will do, have to refine it a bit and test it with real PPF (just to make sure that it can be applied without heat gun and no bubbles, as there are some curves there). When done I will post hereYep! That's it but in my case I was too lazy to remove the original bit so I put a section on top. Please post a link if you end up cutting these as I would gladly redo mine for a professionally cut bit of PPF
You may also consider a small rectangle (6" long ??) for the rocker that jets out just below the piece you show in the picture. I did this section as it was already chipping up.
I am done with the bigger model (fenders + rocker). Here is a picture of installation with cheap vinyl (not PPF) that I use for experiments. Will shoot a video tomorrow and upload it on the store.
You can also buy it here if you want it:
Rear Fenders + Rockers Paint Protection Film for 2021+ Tesla Model S (Plaid & Long Range)
Product Features 🛡 Protects your car's paint from chips caused by rocks ☀️ Practically invisible once installed 🏁 Made with ultra premium self-healing, stain resistant paint protection film 💪 Install in 20 minutes, comes with everything you need for a successful installation. 💎 Precise digital...twraps.store
Thanks, will ship later todayHi, just ordered.. Do you have any advice on removing the factory PPF, or does it just peel right off?
In Europe mudflaps are mandatory and come standard. I installed aftermarket mudflaps on every vehicle I bought. On the Tesla I also installed PPF (the had 14 miles when I did itLove this car. I don't drive it on dirt roads and only hand wash. My rear quarter panels are getting chipped. Looks like the New flare out is catching the road debris. Anyone else seeing this on their car? only 800 miles View attachment 685948his?
Any update on this?I have emailed them to see if they fit the refresh 2021 Model S. Will post response when I get it.
