2017 Model S 90D Loved the power liftgate trunk for a great 6 years. It opened at its tallest about 52 inches (132 cm) from lower trunk gasket to the trunk edge. I call this the head injury/ concussion zone … then it stopped working. Now only opens and closes automatically up to about 41 inches (104 cm) after being replaced by Tesla Service.
So my asks are as follows:
1.Model S owners when you had your struts fixed did it automatically open all the way like it did before it stopped working?
2.Model S owners when you had your struts fixed could you set the trunk at different heights. Just like in the manual?
3.Is there a break-in period for these powered liftgate trunk struts?
If you haven't already tried this, it may help.
We had our lift gate struts replaced on a 2014, and this did not fix it. It turned out that the number of counts that the lift gate's linear motor needs to make are greater on the new liftgate strut. It took the Tesla guys a while to figure it out, but they were able finally to write the correct number to the firmware and get it to open all the way. Well, not all the way. It still stops about 2 inches shy of the top. For me that's okay, I'm not all that tall!
Reactions: mongo
Thanks, I retried setting the trunk but it will not calibrate to the higher opening.
“If the liftgate loses its calibration when opened, the liftgate chimes three times and does not move. To restore calibration, manually pull the liftgate down to close it.” So I think Tesla Service is my next step. Thanks.
I didn’t know about this , so I will see if this is the problem with my trunk.Next step Tesla Service to re-fix.Thanks for the info.
