stopcrazypp
Actually, here's how max power relates to mph (which is directly proportional to rpm because of the single gear):
But keep in mind that this is MAX power. At any given speed, if all you care about is maintaining that speed then you won't be using the max power, but only a fraction of it (like 20kW/27hp for 60mph and 60kW/80hp for 100mph). And assuming the efficiency of the motor is the same throughout the rpm range (true for electric motors, not true for ICE), gearing is unlikely to effect steady speed efficiency. All a taller gear will allow you to do is reach a higher top speed, assuming you don't hit the power limit first (for the P85, the peak power of the motor at max rpm is about 220hp, which is good for about 150mph top speed).
