If you can spring for the 100D it would be better in the long run (if you'll want freedom to do trips often) and for future resale. Range is king, you'll notice that once you own an EV. The acceleration also makes it feel like a truly fast car versus a bit sluggish feel (not that its as bad as some other gas SUVs still).
Do realize you only charge to 90% of stated max range. That last 10% is painfully slow (or last 7ish or so). Then you'll lose some in time when algo learns your driving, you'll lose some due to true degradation over fist year then each year, and in Winter/cold times you'll lose some due to efficiency lost (cold air, heater, any wet/snow roads, etc.). For example, that 237 100% mentioned on 75, at 90% is 213, minus 5% over some years leaves around 200 at 90%, then say you lose 20% due to cold leaves about 160 miles range if you didn't range charge. Not a ton, and 20% is being generous if your in a very cold climate.
