Model X lug nut torque specification
Discussion in 'Model X: Interior & Exterior' started by ohmman, Feb 16, 2016.
  1. ohmman
    ohmman Maximum Plaid Member
    North Bay, CA
    Is the MX lug torque still 129 ft-lbs, same as MS?
  2. brianvicars
    brianvicars Member
    Toronto GTA
    #2 brianvicars, Jun 27, 2016
    @ohmman. Four months for a response? Everyone must be on Tesla time. To answer your question, yes, 175nm or 129'lbs.
    Just received my vehicle which now has 48 miles on the odometer & I wish to torque to specs after reaching 50 miles. I went to the owner's manual to determine the required torque & surprise surprise, its not listed. Is this a hint as to what is to come?
    Bye the way, Maximum Plaid Member. there is a rumour out there that the Model X now comes with 61hp more that the Model S. Although the X is 600 lbs heavier, the vehicles have almost identical acceleration curves. It appears that the tow package was the initial reason for more power. You can leave your trunk insignia P90D, but I think I will change mine to P93.5D.
  3. dbsynergy
    dbsynergy Member
    Dorrington, CA
    What about the lug nut size? It is much larger than the 13/16" lugs on the Model S, but I don't have a socket large enough. Anyone know what the correct size is?
  4. dbsynergy
    dbsynergy Member
    Dorrington, CA
    I just called Tesla and got the answer.
    129 lbs torque
    13/16" with lug nut covers that must be removed.
  5. Gwgan
    Gwgan Almost a wagon
    Maine
    I was told 21mm, which is close by 0.4 mm. I hope the Tesla is build in metric units, not Imperial.
  6. nuevodesi
    nuevodesi Member
    Dallas-Fort Worth, Texas
    I have a minor leak in one of my MX tires as such took it to my local Tire center (a national chain).
    Ran into an issue where they did not have the Lug Nut torque specifications for the Model X. Interesting to note that, I could not find them in my online as well as PDF owners manual. My local Tesla service center and Roadside assistance confirmed the 129 lbs-ft, but weren't able to point to ANY Tesla written documentation for the Model X, for the tire shop to work on.
    Here's more - the Owner's manual index (Page 194) has torque specifications pointing to Page 172, but nothing on Page 172 or even in the wheel specs (Page 175), are Lug Nut torque specifications supplied.
    My guess is that due to lack of documentation, the national chain tire shop has not updated their m&ps for tire technicians. Tire shop required this before they could work on the MX.
    Does anyone else find this frustrating ?o_O
  7. psgabin
    psgabin Member
    livingston, nj
    same exact thing picked up screw in tread, took it to tire shop, turned out they just took screw out no leak, but said if they needed to remount wheel no idea what torrque to use. their charts have no tesla
  8. Michelx
    Michelx Member
    Alma QC Canada
    dbsynergy do you know what tool is needed to remove the lug nut covers ?
  9. ohmman
    North Bay, CA
    Frustrating, yes. Surprising? Sadly, no.
    The good news is that this is why I started the thread. I didn't even have my X at the time!
  10. vandacca
    vandacca ReActive Member
    Hamilton
    You can remove the Lug Nut Covers with this tool.
  11. Michelx
    Michelx Member
    Alma QC Canada
    Vandacca thank you .
  12. nuevodesi
    nuevodesi Member
    Nice .. One will be delivered today and will go into the MX's glove box.
