Since this station opened a few months ago, charging my care was very normal. But that changed this weekend - could it be related to the grid load this weekend in New York City?
More details might be helpful.
It just stopped charging at 190 miles even though you had set it to charge higher?
Was the charging kW power typical up until it stopped?
Did you try a different stall?
How many other cars charging while you were there?
these are all excellent questions concerning items that I should have included in my request - my apologies.
1. Yes, it stopped at 190 after I received the usual time warnings on my phone.
2. Yes, the charging KW power was the same as it is always
3. I went to a different stall each time
4. Each time it was one other car charging as well.
When I charge there again this weekend, I"ll change the limit to 'max' to see how far I can go. If I reach the usual 227 miles (80%)
At one time I started charging with 40 miles left - the second time I started with little over 100 miles left. The charging ceased both times at the same place - exactly.
I could ask another driver, but the stations are in the parking lot of a Macy's and everyone goes inside the mall to pay the $3.00 charge and use the facilities, etc.
So if you set your car to 80% charge, does it charge all the way to 80% charge then gives you the message "Charge Complete"?
Or when you set it at 80% and it stops charging at 70% then gives you the message "Charge Complete"?
Or are you talking about that setting at 80% would give you 227 miles last week and now the same would give you less like 190 miles at 80% "Charge Complete"?
Yes, when I set the charge level to 80%, I receive the CHARGE COMPLETE message at 190 miles.
To your second question: when I set it at 80%, it stops at the 80% mark but is only 70%.of the miles.
And yes, previously I would regularly receive 227 miles at 80% in prior weeks.
I suspect you have set your car to "Ideal" range.
Most people set it to "Rated" range.
Here is a quote I found:
"New Model X 75D owner. On a full 100% charge the total miles shown is 295 miles with Ideal mileage option. With Rated it's 237 miles."
Hmmm....I do remember playing with those options, and not really understanding at all what they meant.
I'll take a look this evening, and if so, will change it to RATED range.
I'll get back to you and thanks either way! I'll also research what each one means (as I should have done initially!)
Thanks for everyone's input! This morning before I took the usual mass transit to work, I looked at the settings on the car - it was in RATED mode and about 188 miles. I toggled it to IDEAL and the mileage indicated 210! I read up on what they both mean, and decided to keep it at RATED because it would more accurately reflect the 'normal' miles with factors such as weather, weight, etc. considered.
I appreciate everyone's help! This was a good learning experience for me.
