Knightshade
Although, in this case, they did make some improvement, even though this might not translate to the Tesla. The video shows they got a 5' shorter stopping distance compared to stock brakes, which means that the improved ones (whether they're $450 or $4,500) do make a difference.
Their results presentation is... kinda disjointed there...
They show the "stock" distance at 88 feet in one car (which is actually 11 feet shorter than the $450 upgrade distance)... but then show the stock brakes at 106 feet in the second comparison?
And yet they only get a 5 foot difference from stock with BOTH the 88 and 106 "stock" distance?
Likely you're just seeing differences in the drivers reaction time in that 5 feet.
Here's how you professionally measure braking distance:
Brake Testing Measurement and Accuracy
This insures the "start" of the braking event is always known to the calibrated measuring device regardless of human reaction times and it's measuring in multiple ways and cross checked for validity.
it's the kind of testing the car mags use, like in the example I posted earlier of testing a 911s stock brakes against the $10,000 PCCB brake upgrade Porsche offers where distances were basically identical for both in even 100-0 tests...
That said- sure it's also possible the stock brakes were in terrible shape or something- and ANY upgrade (even likely new OEM parts) would've got you that 5 feet.... the fact the difference was exactly the same with two vastly different replacement brake kits kinda hints that's the actual case.... if the BIGGER ALWAYS STOPS BETTER idea was true the $4500 kit and $450 kit wouldn't show the same 5 feet after all.
