MountainPass Performance Comfort Coilovers
Dr.Will
231
168
Irvine
@Dr.Will that looks clean af with the te's. I personally experienced little settling. Maybe a couple mm at most. Ride stayed as good as the day it was Installed.
Definitely good to know! I’ll drive then get alignment in 500-1000 miles. Thanks again for the help
Wreckz
165
104
Honolulu, HI
Just finished installing and drove through some rough roads to my moms home and I’m very happy with the results. The Y now takes the bumpy roads, train tracks and uneven pavements way smoother! Gonna test it out some more tomorrow on a small road trip to Los Angeles.
I lowered the Y about 1.5 all around but may raise the front up a tad once it settles. Really enjoying them!
I’ll get some better pics soon.
Looks sick!! I'm in the a similar boat, should I raise my front or lower the back by 4-8mm to even out the fender gap. I know my car is raked a bit due to tire size in the rear adding 4mm to the diameter of the wheel.
Dr.Will
231
168
Irvine
Take some more pics!! I think drop the back a tad bit more?
I have about 1 finger gap in the rear but I do have fat fingers 😬
Wreckz
165
104
Honolulu, HI
This is the best picture I have so far to represent wheel gap. Been wanting to drive to the North Shore to get a better backdrop, but been lazy.
I have about a 1.5 finger gap front and maybe 2.25 gap in the rear.
Wreckz
165
104
Honolulu, HI
I don’t believe this is correct. As I mentioned in my post, I went with NPP recommended settings which are 14 clicks off of Max stiffness.
I did them myself and they were clearly 20 clicks For both rebound and compression on both front and rear. If I miss read your post, I apologize.
Hmm I think @gundarx is right. When I adjusted my front bump yesterday I couldn’t go past 14. Maybe I wasn’t in a good position to adjust bump. My thumbs and fingers were fatiguing when adjusting them.
Pianewman
925
613
Fort Worth
I was also referring to the unspoken "butt dyno" results that we're all guilty of, after spending $3500!!!! The advantage of my delayed MPP delivery date will allow slightly longer-term evaluations for me to read about.
Thanks for all the positive MPP posts.
dfwatt
3,078
5,090
FL
I have about a 1.5 finger gap front and maybe 2.25 gap in the rear.View attachment 659633
I think this setup is the sweet spot for wheels and tires on the Model Y - reasonably lightweight 20in Wheels with the 265/40 - 20 Michelin Pilot Sport 4S. More comfortable for sure then the performance wheel and tire package, not much range sacrifice compared to the 19's and great grip, probably better than the performance package, and way better rim and tire protection. It ticks all the boxes, and excels at numerous parameters without any major sacrifice in range, comfort, performance or durability. Plus it's really good looking. I think you nailed it!
Reactions: pt19713 and Wreckz
Wreckz
165
104
Honolulu, HI
I was defiantly shooting for a little meaty look on tires. The rear is 9.5 inch wide on 265. The front is actually 255 on 9 Inch wide wheel. Not sure why it’s a bit stretchy but it’s fine…
Reactions: dfwatt
dfwatt
3,078
5,090
FL
I actually think the 9.5 inch rim is better with a 265. I've got 265 / 30 Pilot Sport 4S fronts on a 9.5 and they sit really nicely– not stretched but not squeezed either. It does make the tire look really meaty, again really nice job! I'm assuming you've got the Comfort coilovers?
Wreckz
165
104
Honolulu, HI
I actually think the 9.5 inch rim is better with a 265. I've got 265 / 30 Pilot Sport 4S fronts on a 9.5 and they sit really nicely– not stretched but not squeezed either. Again really nice job! I'm assuming you've got the Comfort coilovers?
On the 9 it’s weird why it’s stretched.. but yes the 9.5 with 265 is perfect imho. Also if I went with 10s my tire selection was limited (285/40).
Yep comfort coilovers. No regrets getting them. 14/14 and 14/12 is were it will be at for a long time.
Front stretch
Reactions: dfwatt
dfwatt
3,078
5,090
FL
Front stretch
Yeah that should be about as comfortable as a Model Y can get. I went in the other direction – Batmobile handling! But I suspect your Y both rides much better and handles better as well.
Reactions: Wreckz
dyau
93
47
seattle
I’ve tried to very soft 14/14 all-around, but there were more turns to go even softer: MountainPass Performance Comfort Coilovers
I drive through Seattle occassionally and know I-5 near the city is bumpy and the local roads are jarring on stock suspension. You’ll be happy with the night-and-day improvement at 14/14 but you’ll lose the sporty edge; if you go softer it might start to feel like driving a jeep cherokee
I’m currently using these settings and with tires at 41 psi on the 21” uberturbines and is the right feel for me even in Seattle streets:
front 12/12 (compression/rebound turns from full stiff)
rear 12/10 (compression/rebound turns from full stiff)
did you get yours installed in seattle area? and how much did it all cost?
Wreckz
165
104
Honolulu, HI
100% correct. At those setting it still handles a little better than stock on twisty roads. Only difference is going over a hump on freeway I can feel the car bounce a few times before it settles down. My nephew and nieces loves it when that happens.
Reactions: dfwatt
2020
145
-8
atlanta
Planning on installing mine next week. I have 20mm spacers in the rear and plan on lowering it about one inch or whatever Mountain Pass recommends. Do you guys think I should have enough clearance.
Reactions: pt19713
pt19713
919
1,108
Delaware
It depends on the wheels, tires, and negative camber specs. Also, 1" on a P will be different than 1" on the LR.
sirpumpkin
25
7
Lafayette, Colorado
Hi! Dumb question. I got these installed on Monday. Ride is noticeably softer at setting 14/14. I want to firm up a bit. The rear wheels are easy (I didn’t adjust height).
For the front. I’ve removed the front trunk cover and can see where I need to adjust. However, I can’t get to adjustment on the right as the windshield wiper fluid is in the way. Do I need to move this?
Also for the adjustment in the front near the tire, can this be reached by hand? Any tips? I don’t have a lift.
