Hello, I have the issue with the camber on the rear wheels on my MS 85 2015 (Rear motor version).
After the motor service (the subframe was removed, as well as upper suspension arms) and reassembly, I faced the issue of enormous rear tire wear on the inner side. On the photo - this is what happened after ~2500km. I never had such problems before, with the same upper arms and all other parts.
It looks like there is no "official" way of how to align the rear camber, and the factory spec value for it is -1.35, which I find very strange. The rear toe is fine aligned and in specs.
What could be a solution, except buying a custom upper adjustable arms? It is very strange for me that after the rebuild the issue appeared, even though all parts are the same and aligned.
And if there is no other way - what should be the value for the rear camber in case of adjustable arms?
