A message from Bristol SC to an affected owner. It's on the UK FB group somewhere.Source please.
This is really not such a big issue as some make out. It's managable and Tesla are managing it well IMO.
It's not affecting all early RHD 3s though is it? There may have been a small number with that early loom where the connector is more vulnerable for some reason. Who knows? I've been through massive stretches of standing water at speed with no issues.
I'm not trying to be difficult, start an argument or over dramatise things, but there's no way this isn't a safety issue. Tesla have just issued a recall for early model X's where the power steering bolts might rust and could snap losing power steering. Now if they feel that this requires a recall, then how can this known and rectified fault not also be a recall, as with the bolts it's possible that only a small percentage of people will hit the issue, but it's a fault that has been rectified and needs retrofitting to everyone rather than just wait for it to maybe happen.I'm not suggesting you or your wife carry on driving it with those systems disabled the whole time, but it's possible to drive the car without crashing and many have in order to get it home or to a SC.
If you're too nervous about it, stop and call recovery. It's always an option.
if my connector exhibits this problem at some point, I'll return to this thread and you can say "told you so".![]()
SR+ VIN 463XXX has the issue, day 0 order but was one of the first in the country with a tow bar so was not in the first batch of deliveriesAffected VINS
If anybody affected or has had their car fixed, I would and I am sure others would really appreciate it if you could confirm the VIN range of your car.
Out of the last 6 digits of the VIN ie 413XXX
Appreciate any feedback from affected users
@bjbrown
@CMc1
@Surf-Edinburgh
@pacman65
@Beaurobyn
@navt
@Andy_T_73
@Plagued
@victorgse
See my earlier post Multiple system failureIf anybody affected or has had their car fixed, I would and I am sure others would really appreciate it if you could confirm the VIN range of your car.
Performance VIN 448XXX does not (yet?) have the issue and was on the boat before the SR+
If I can get some info on what part of the harness has the issue, I'll happily pull the frunk cover off the Performance and see if I can see the beginnings of any issue.
I also have an SR+ with tow bar and Vin 463XXX ... (delivered 4th September 2019) no problems so far but you are not filling me with confidence!
490xxx
4300 miles
2019 oct
nothing yet
From FB group. The problem apparently stems from a piece of trim not being flush with the bottom of the windscreen on some cars, so it sticks up and water running down the glass can get under it and onto the connector. So just check how yours is positioned and if it's sticking up push it down to where it should be.
Thanks for this. I just checked mine and can see that the plastic trim is flush, i.e. not projecting above the window. However it butts up against the window rather than slipping underneath it. It appears that there is a seal at the base of the window which maybe should overlap the trim?From FB group. The problem apparently stems from a piece of trim not being flush with the bottom of the windscreen on some cars, so it sticks up and water running down the glass can get under it and onto the connector. So just check how yours is positioned and if it's sticking up push it down to where it should be.
Mine's the same as yours. It doesn't (and I don't think it's designed to) underlap the glass. I think as long as it's not sticking up i.e not seated properly, it will be OK but if you're concerned I would suggest removing the frunk and checking around the connector as I'm going to do once it stops bloody raining!Thanks for this. I just checked mine and can see that the plastic trim is flush, i.e. not projecting above the window. However it butts up against the window rather than slipping underneath it. It appears that there is a seal at the base of the window which maybe should overlap the trim?
Currently it looks like rain could still get down through the join area - the screen and trim are flush but no overlap and seal, so still a small gap. How does everyone else's look please?
Ah good. I was thinking it would be a major issue if the whole thing needed to underlap. However I'm still not sure where the water goes after its sneaked down through that crack. Maybe reseating the trim makes another seal underneath somewhere? Nailing it down here in Derby so likely will need to wait before I start taking the frunk to bits. But please post back if you spot anything. CheersMine's the same as yours. It doesn't (and I don't think it's designed to) underlap the glass. I think as long as it's not sticking up i.e not seated properly, it will be OK but if you're concerned I would suggest removing the frunk and checking around the connector as I'm going to do once it stops bloody raining!
I wonder if it would be an idea to disconnect the connector slip a piece of heat shrink over it. Reconnect it, heat gun to seal the heat shrink.
Don’t know about disconnecting the connector, if that would affect the car?
Thoughts
Dave
I’d never heard of that tape before. A quick search, looks good, saves disconnecting the connector. Might be worth a tryI was thinking of self amalgamating tape that can be fully waterproof and can be easily cut off if access is needed in the future. It's often used for outside connections for aerials and the like, as well as some automotive stuff.
Does look worth a try. However, looking at the pics in the thread above, presumably water shouldn't be getting there? There's also electical gubbins on the other side? Anyone able to comment on how easy (or otherwise) it is to get to the connector please?I’d never heard of that tape before. A quick search, looks good, saves disconnecting the connector. Might be worth a try
Actually, I've just realised you don't need to remove the frunk to see that connector. You just pull off the bit of trim which gives access to the brake reservoir. So it's very easy.Does look worth a try. However, looking at the pics in the thread above, presumably water shouldn't be getting there? There's also electical gubbins on the other side? Anyone able to comment on how easy (or otherwise) it is to get to the connector please?
