Navigation zoom while still seeing % estimate when arriving at destination
Discussion in 'Model 3: User Interface' started by clicketyclack, Jan 24, 2019.
  1. clicketyclack
    clicketyclack Member
    New Jersey
    Currently when I swipe down on the navigation to see the estimated % battery I will have upon arrival the map zooms out. Was curious if there was a way to have the map zoomed in and still see the % battery estimate.
  2. clicketyclack
    New Jersey
    does anyone else have this issue?
  3. srjinatl
    srjinatl Member
    Marietta GA
    I think that is just the way it works - I am going off memory - but I believe that is how mine has worked since day 1 of owning the car.
  4. Derek Kessler
    Derek Kessler Active Member
    Cincinnati
    When you swipe down line that you're telling the nav software you want to review the whole route, so it shows you both the full list of steps to come and the complete trip map.
  5. Big Earl
    Big Earl Supporting Member
    Springfield, VA
    There is a way to make it show the zoomed in map while displaying percent, but it's tricky.
    While Supercharging, but before you have enough to make it to your next destination, click on the map orientation button to make it either North Up or Heading Up, whichever you prefer. Then, click on CONTINUE TRIP. This will give you the step-by-step directions with estimated arrival state of charge while showing you the zoomed in map.
    Note: if you back out of this view, you won't be able to get it back until you charge again.
  6. ewoodrick
    ewoodrick Active Member
    Buford, GA
    It seems to zoom the map to show all the points listed. If you have the number of points decreased, then you are zoomed in close, expand the list and you zoom out.
  7. clicketyclack
    New Jersey
    Thanks guys. I'll try the supercharging trick. I tend to use navigation on longer road trips and having an easy way to do this would be very nice.
  8. APotatoGod
    APotatoGod Member
    Similarly, I'm annoyed by being unable to see the "heading up" view, while also seeing all upcoming steps (in addition to the estimated remaining %), it's frustrating to be forced to use only one of these views at a time, I hope they fix this behavior soon
  9. clicketyclack
    New Jersey
    good to know i'm not the only one!
  10. Need
    Need Active Member
    SoCal
    I don't think I know anyone who loves the new steps hidden function.. some are okay with it.. but most hated it. It is always good to see the next 3 or 4 steps and the keep an eye on the estimated arrival charge...
