Call your city/county permit branch and ask, or take a look at their permits web site. It should be listed. In Washington state, all electrical work done by anyone who is not the owner must be accompanied by a permit and inspection. I'm sure certain things done by the owner still would require permit or at least inspection, but not 100% sure. My electrician pulled the permits and setup the inspection for me, so I just paid him, and then stayed home for the 10 minutes it took the inspector to approve it.How can I find out if I really do need a permit?
A 40- or 50-amp outlet doesn't require a permit? Weird. Does it at least require an inspection?Funny thing. Here, in BC, if you install an EVSE you need a permit. If you install a receptacle for an EVSE to plug into, you don’t.
Is that concrete wall ? Also this looks like standard Siemens /Murray qo breakers can get for less than $15 for 50a ..hardest part I see on this job is coming out from the concrete
In Washington state, all electrical work done by anyone who is not the owner must be accompanied by a permit and inspection. I'm sure certain things done by the owner still would require permit or at least inspection, but not 100% sure..
Than that is rip off lol ..u can do ur self it’s not hard
That panel is completely full. It looks like the bus only has 30 positions but and they are all full.
It appears that none of the slots are rated for “tandem” breakers either from what I can see (though I may be wrong - I need a close up of that sticker on the door to tell - please also post pictures of the circuit list so we know what they are used for)
Weird though. Most of the time at least some positions are rated for tandems (they usually allow you up to 40 total breaker poles, so a 30 slot panel will often have ten of the slots allowed to use tandems)
There are 6 open slots on top. 3 kn each side. Why couldn't I use 2 of those?
