Hello there,
I had an electrician installed a NEMA 14-50 outlet (50amp) back 4-5yrs and didn't think much of the outlet and location. So, he just added that outlet probably 4 ft inside from my Garage door. Using a plastic box looking outlet. not sure what brand. Now that I have a Model 3, I wanted to relocate the outlet closer to the garage door opening so I can plug the mobile charger or install a wall charger near the opening using the NEMA 14-50 plug&play.
1. Can I extend the 6/3 wire to relocate the outlet from the existing outlet? Or do I have to run it directly from the Panel and connect directly from the breaker?
2. Can I do this myself instead of having an electrician to do it?
3. I see a lot of people here uses Hubbel Nema 14-50 outlet. Is Bryant brand any good?
