I am planing to install NEMA 14-50. The problem where I should install it.
I have Tesla 8.16 Kw PV and 2 powerwalls with a whole house backup. The backup panel is 90 amps, in the biggest breaker is AC at 50 amps, the rest of the breakers are 20 amps. If I install NEMA 14-50 with 40 amp breaker.(I’m not planing to charge the car at the max amp available but just want to take an advantage of Solar in the afternoon after powerwalls fill up).
Will it be safe to install it in the backup panel? Or I should install it at the main panel. Any thought?
Thank you
Thank you
