I've also been looking into this. Let's just say I won't be investing in it.
Reading through some studies on articulated / 18 wheeler trucks, firstly the trailer typically accounts for 60% of the aerodynamic drag and secondly with a full load, rolling resistance is still the dominant factor for most of the speed range. My calculations also show the latter up to 56 mph.
It has also been found that the teardrop shape trailers you sometimes see actually don't do as much as claimed (M&S in the UK apparently reported to one study that they will keep the ones they have for "environmental advertising" but wont order any more). Side skirts help but there is not much you can do about the gap between tractor and trailer. Clearly Nikola Motors has little control over what type of semi-trailers their tractor units are going to haul. The large box that I think holds the fuel cell behind the cab on their design also forces a large and undesirable gap between the corner of the cab and front of the trailer.
I've therefore used Cd = 0.6. I also saw a presentation from
Nokian tyres that shows for truck tyres, the Crr is a bit lower than car tyres. It obviously depends on the axle configuration but driven wheels are around 0.007 and trailer wheels 0.006. I've put the latter in for simplicity as most of the weight is over the trailer wheels and there tends to be more of them anyway. I am also being a bit generous with the cross-sectional area as I am using 10m^2 but looking at a few trailer dimensions around 11 is more usual. I used 40 tonnes in my calculations but I see from other sources since that 80,000 lbs (36.3 tonnes) is the typical GVW for such trucks in the US. It is this that Nikola states they can haul over 1000 miles in their press release.
Now, taking Nikola Motors' claims at face value, they say they have an *up to 70% efficient fuel cell and *up to 95% motor. They don't state anything about reduction gears efficiency, but in the video presentation their CEO states it has 6 motors (one on each wheel) and gearing gives a 5x multiplier on torque. They have shown some simple gearboxes on their Twitter feed..
Therefore, if I take 95% for each of the motor, voltage upconverter and inverter, and 70% for the fuel cell, I get the following.
Now, the claim of 95% efficiency for the motor with no gearing loss is frankly a bit unrealistic, so I will set that to 90%.
Also, and for me this is the killer, 70% for a fuel cell efficiency - even when using LHV of hydrogen - is <ahem> a big improvement on other manufacturers. I googled "300 kW fuel cell" and
found this, which is a static hybrid energy recovery type of installation running on natural gas, where waste heat is fed through a turbine.
Given that their CEO doesn't even know what PEM stands for - the object that is pretty fundamental to the working of your product (check the video) - and given that Nikola suddenly switched from a gas turbine range extender to a hydrogen one not long before their big reveal, I might suggest that they put a similar amount of research into this thing.
For manufacturers already making larger fuel cells for commercial vehicles, such as Hydrogenics, they claim around 53% efficiency (LHV) for their cells in the up to 200 kW range. If anyone can point me to a real mobile fuel cell that is getting 70% efficiency then please let me (and every other manufacturer) know.
So, if I go back to 53% efficiency for this, like other mainstream large fuel cell applications, then I get the following:
Interestingly if you put in a more sensible weight just for the tractor unit (say 8 tonnes), then range is 999.8 miles with the 53% efficiency fuel cell...
Perhaps if they are not trying to pull a fast one, then someone else is pulling a fast one on them. It's a shame, as the idea has merit, but give it closer to 200 kg of hydrogen and it might actually reach the numbers they claim with a full load, albeit without the "2x the fuel economy of a diesel".
Looking at their claim that they will build 100 MW solar farms to generate the hydrogen through electrolysis - I've already shown why that is a bad idea on the hydrogen vs battery thread. There I linked to a recent study showing that for a real world, 350 bar electrolyser the energy required is 62.2 kWh/kg.
I took a site in Southern Spain as an example of somewhere analogous to Utah (the EU has a nice solar output calculator) and at 100 kg per truck, that's 69 trucks per day output.
Toyota has an array that is 9 hectares and 4.1 MWp at their Derby plant in the UK. They state this is designed to produce 4.3 GWh per year, just a bit less than one truck's worth of electricity. I therefore recon a 100 MWp peak array would be 220 hectares. The Toyota plant is 235 hectares including the test track, or 2.5 by 1 kilometres in size. You can see the size of the PV array relative to the whole plant in the bottom picture - the array is in the north west corner.
I also can't figure out why they need 320 kWh. That's >2 tonnes of batteries in addition to approximately 2 tonnes of hydrogen tanks and 1 tonne of fuel cell. I reckon that 320 kWh is enough to climb 2500 metres with a full load or accelerate from 0-60 mph more than 30 times on battery. If you look at their twitter feed they state they are using 32000 individual 18650 cells and they show them packed into what looks like 19" racks, so I doubt they have the energy density of a 100D pack.
Obviously I have made some assumptions here as they have not been completely forthcoming with the spec, but I doubt I am that far off. I frankly don't believe the 70% efficiency claim and the CdA is probably in the right ballpark. They don't specify what speed their range claim is at, so I can't see it being near 60 mph.
