Hi Folks, I just installed an HPWC using the 6AWG copper wiring from my 14-50 outlet. I set the dip switch to 0 for test mode and flipped on the breaker. The HPWC behaved exactly as the manual said, green lights, sound of contactors activating, followed by a solid green light on top and red light flashing 3 times (dip switch set to 0). I flipped the breaker off and adjusted the dip switch to 8, 40A output. I flipped the breaker back on and the HPWC came back up with the bootup sequence followed by a solid green LED on top. I connected to my MS and I get either a solid Blue or Orange light on my charge port and the top LED on the HPWC is still solid green....no other activity. The MCU indicates that the charge port is open, but does not indicate charging or even a cable fault.
Any ideas?
Any ideas?
