Yep, we agree totally .
The OTA / API data does not contain capacity numbers, only range and SOC. (Teslafi works with range as the degradation number).
Tessie tries to calculate capacity from charging (in a way the same way as I could forecast the real capacity on my Plaid when I got it with a grossly wrong estimated capacity by the BMS). It works fine for the sctual capacity but initial capacity is not that easy. Not all have Tessie from day one.
And a BMS that has not hotten the time to adjust the estimate might give wrong numbers if you get Tessie from day one.
Well, its a mess!
For many people it fool them to think they have very little degradation. People still mess up “usable capacity” which was changed to “capacity” recently = good thing.
Its extremely common in degradation discussions on facebook groups that prople think they have 1-2% degradation when the real BMS estimate is 7-10% or so.
Discussions about using slightly lower SOC do not start well when people always doing 90% says “I only have 1.5% and I charge to 90% which is the reason for my low degradation”.
In the end they find they was fooled by Tessie and also the charging tip Tessie gives on their home page. I havent checked it recently but they said 90% was the thing to reduce degradation.
