Hi,
Yesterday my M3LR arrived, brilliant but are my expectations too high or is this something you would log with Tesla? (if the latter how?)
1) How can the right side of the screen show battery % and estimated miles? It's clunky to keep switching between them on the driving menu.
2) Small amount of water in the frunk, normal? I presume I need to purchase an after market liner?
3) Lots of white spots on the paint work, mainly around joins and hinges, they do rub off with a damp cloth, but I would expect this removed before it's delivered!
4) Rear boot liner (sudo carpety type thing) feels loose, I can push it down and it rebounds up a little.
5) White marks on the driver side and rear drive pax door pockets.
6) White marks on both rear parcel shelf speakers
7) Water on the rear boot seal, not in the boot, but is not expect to see water in the grove between two seals
8) Random white thing between two panels in the car, too firm to pull out, about the length of a cotton bud and the width of 3 of them.
9) Telsa badge on the frunk has bit of sticker/plastic covering still attached, does not easily come off.
10) Edge of bonnet where it joins the windscreen and side panel the plastic/rubber join is open, i'd expect it flush to the body work.
11) More white marks around the bonnet edge
12) Rear bumper fitting around light cluster does not look flush to the light cluster
13) How do I get the car to show the front camera? Pressing the "eye" on the right side only brings up the rear and 2 of the side cameras.
Am I being a grumpy Yorkshire man or are (some) valid?
On a side note I have TelsaMate up and running, that's great!
Thanks
Thanks
