Watts_Up
If there's a lot of supercharger close together you can arrive a 5% and leave at 35% which makes your stops very fast like around 5 minutes.
This works only in areas with high density of Superchargers located right by a freeway exit, and driving alone, because
in general, if you have passengers, they would like to stretch their legs, and also use a restroom or eat something wen you stop.
Most generaly when driving cross country, Supercharger locations are quite sparse, and not always next to an exit.
You need also to get an higer charge, just in case there is an accident or a road construction forcing you making a detour.
Also weather conditions, in particular high wind, can increase a lot your consumption.
And driving at high speed, especially above 80-85 mph will affect your pre-estimated range.
Something you didn't mentioned is that below 20% preconditioning will not be activated, affecting you charging time otherwise.
So when preparing a trip using A Better Route Planner, I like to selected my next stop with still having about 30% of charge,
for all the above reasons. Most of the time, I take advantage of a charging stop to also eat someting, so charging time up to 70-80%
is not an issue, while my passengers also apreciate a lower number of stops.
In fact, because of the additional rest time, after a long journey trip, I feel much more relaxed
and don't feel too tired compared with a similar trip using an ICE car and making a lower and shorter number of stops.
