I qualified for a 3 powerwall install in September of 2020 due to being in something like 6 PSPS events and being on a well pump for ALL my water needs. It took until this the end of last month to finally get the installation. The installers did have an issue putting in the soft start on my heat pump so they are returning on Monday to complete this item.
After reading a bunch of the forum posts I have a few questions.
PTO approval, will PG&E contact me directly with a letter, email something when they have given approval?
As far as my rate plan change after PTO approval do I just go online into my account and select EV2-A if that is the rate I want to be on or should I call PG&E directly to have the rate plan expedited? Does it take a billing cycle or longer to change my rate plan?
With the 3 batteries I should be able to easily power my entire home from 3pm to midnight with at least a 25% reserve. Basically I want to only use battery power from 3pm to midnight and use no grid power unless it is absolutely needed. With that in mind should is customize the Tesla app to timed based control, cost savings, and put in the rates and times for the EV2-A plan?
Thanks in advance.
Thanks in advance.
