New SR issues
vickh
4,618
1,241
az
1.Water leaking into trunk space after car wash
2.Rear AC vents blowing hot, front works fine
3. UMC clicking not charging/ SC works fine. Hopefully an EZ swap.
How much can a mobile guy fix ? Appt. next Wed. If I select too many issues it defaults to in person service. Overall car drives beautifully.
Just yesterday I reached back to check the air flow from the vents for the rear seat area and it was blowing hot air. Then later when I checked again it was pretty cold. Can't speak to what happened as I don't know o_O. And I do check the manual from time to time to understand things. I can say my vent setting for the rear area is On. Think it was on before too but not sure. Sometimes I think there should be a dummies guide that would go into more behind what the manual says. The forum is the next best things I guess if the right person reads your post and has an answer.
Reactions: vickh
Does your UMC start charging then give charging interrupted notices? Have you tried at a different outlet/house to make sure it’s not your wiring? My UMC went bad after about two weeks (didn’t work on other outlets or at another house with brand new wiring), but a ChargePoint location worked fine. I called service center parts department, explained to them and they FedEx’d me a replacement (I’m about 2 hours away from an SC).
Reactions: vickh
Yes different outlet/house. Did you call 800# or local service #?
there's another thread, but no resolution. Wife said she wouldn't take another trip in hot AZ w/o it ;)
