The foam in one of wheels had separated ... causing the imbalance in alignment leading to the vibration.... they put on a new tire, aligned the car and it’s good as new... no vibration.. will see if it comes back
Standard will give you even wear. Low will wear the insides of the rears.
I'm afraid it's not even that simple, I think you'll be told different things at different service centers, and I think some postulation on this forum is treated as fact. I'm not convinced we have a concrete answer to whether or not camber can even be adjusted, much less whether or not it is different after a certain build date. Several people suggest it can't be adjusted, but I've also read that a service center will align on low if you ask them to and told by my service center that they always align on Standard (even though I've had my X come back to me on Low when I sent it in on Standard). Regardless, yes, this:I'm afraid it's not quite that simple. Newer cars are set to give even wear at low ride height.
All you can do is monitor your tyre wear closely at whatever ride height you choose to run and take action accordingly. Lowering will generally increase camber and inside tyre wear, raising will reduce it, but the optimum height depends on how the static camber was actually set.
I agree there is conflicting information kicking around from both forum members and service centres. As an automotive engineer I can't believe there would be zero adjustment in the static camber, but quite possibly a very restricted range of adjustment. But I do know for certain that I have even front and rear tyre wear across the treads over 10k miles set to always low. Actually the fronts are wearing fractionally more on the outside of the treads, even at low ride height, but I'm talking less than 0.5 mm from outside to inside. So if I did run standard ride height I would get more outside tyre wear for sure.
That's why I always say that you can only monitor your own tyre wear and if they are not wearing evenly across the treads you can either adjust the ride height to compensate or put pressure on your service centre to do something about the static camber settings at your preferred ride height. I don't think there is any other way of dealing with the inconsistency we see from build to build. It's certainly not a simple case of standard ride is optimum for tyre wear. Not on my car anyway!
That's crazy. My invoice says customer has been notified new half shafts design is coming and has opted to wait for it. I'd be very upset if I was you (as if having shudder wasn't enought to be upset about in the first place). Has anybody heard an update on the "bulletin" about new half shafts design?Tried to get mine serviced here in Toronto for this shudder problem I've had for a while and was told it is normal when setting the height to standard or above.
Many street cars have non adjustable ride height and non adjustable camber or caster. Toe and go as alignment shop put it
Nah, there is, but it's only applicable in an alternate universe and/or timeline at the moment.So after 8 pages, indeed there is NOT great news..?
Actually I think you meant 8 pages & 3 (more) months, with no real fix - not even out there on the horizon, somewhere.So after 8 pages, indeed there is NOT great news..?
