received 2019.16.2 today. Great update and was so excited to see NoAP in UK at last.
However, first use and two very worrying incidents. Motorway lane changes were fine, no issues whatsoever. Note that this is indicator (turn signal) initiates after on-screen prompt. The issue came with motorway exit. The car manoeuvred to the inside lane well - each change with prompt and driver initiation. However, with motorway exit there was no requirement to initiate and the car started to turn towards the exit ramp. On both occasions, there was an issue. First time, car got about halfway over the dotted lines and then abruptly jerked back to the right and into the inside lane. I had to intervene and sharply turn back to the exit ramp. Quite startling and worse than usual ‘aborted lane change’. Second time it dithered back and forth a little - very hesitant and at last minute took the exit.
This is properly dangerous. Suggest utmost vigilance whilst using this feature, especially on motorway exit. Have reported to service at Birmingham who mentioned they have received a number of calls today and that ‘there will likely be an update removing the feature over the weekend’. This I doubt, but unfortunately it would seem prudent. Whilst vigilant folks will not come a cropper, there is a significant chance of the sort of incident that hit the headlines in the US when a car on AP fluffed inadvertently moved into exit and then changed its mind and hit the dividing barrier.
