Noisy door weather seals causing stiction noises over bumps?
Does anyone else have noisy door weather seals? The door or window actually sticks to the seals, and as you go over larger bumps such as driveway entrances or speed bumps, you actually hear the frame flex a bit and break the stiction. I've tried using wd-40 silicone lube on the seals to prevent this, and it does for a few weeks.
Wondering if anyone else has this odd issue and a longerterm solution? 2023MYLR 4000 miles.
