I'm hoping that the automatic home garage parking feature coming Real Soon Now will do back in parking. With all the ultra sonic sensors it's seems very reasonable technically.
Interesting, that's far worse than I would have expected. Even pretty cheap ultrasonic sensors can measure distances with better than an inch accuracy, actually better than a cm.It depends on the accuracy that you want. The laser is probably good to an inch; I have found the ultrasonic sensors to be +/- a few inches in accuracy in my garage.
Interesting idea. Of course, I imagine I would have to run two circuits, as daisy-chaining the outlets is probably not up to code.
Well done.Note: The switch below was to offer a solution for others. I listed the charger on PlugShare, as there are VERY few charging options in my area. This month, 3 Teslas and 1 Leaf have charged up.
Cool idea. Of course I that case I might just put in a subpanel. It would make it much easier to install an HPWC in the future.Well....I put in a transfer switch.....and it is to code. This example (pic below) has a NEMA 14-50 and an HPWC on the same circuit, routed through a manual transfer switch (inside the building). The same could be done with 2 14-50 in a garage. Note: The switch below was to offer a solution for others. I listed the charger on PlugShare, as there are VERY few charging options in my area. This month, 3 Teslas and 1 Leaf have charged up.
I don't understand; does the manual transfer switch allow 80-amp charging through the HPWC, OR 40-amp charging through the NEMA 14-50, or can both run at the same time?
It's either/or. Both cannot run at the same time. It's a way of using smaller cables, and 1 X 240 volt (2 pole) circuit - in response to the original question on the thread about running 2 14-50 receptacles on one circuit.I don't understand; does the manual transfer switch allow 80-amp charging through the HPWC, OR 40-amp charging through the NEMA 14-50, or can both run at the same time?
