Yes...i think. Smart summons works great for example. All stop lights visible etc. Initiated lane changes work great etc.
But...another update. Just came back from a test drive. If we enter a destination that has some "freeway" sections the blue "Navigation on autopilot" pops up. However if we select a destination where there is no "freeway" on route, the blue "Navigation on autopilot" button does not pop up. I'm wondering if we actually drove to a section of highway (for us about 60 km away) if we would get the solid blue single line.
Thoughts???
And by the way Angela and I appreciate all the help.
Basically yes. The NOA blue button shows up when some part of the trip can use NOA. However, the car will only show the single blue line when NOA is actually engaged .. so you won't see the single line until you are on a freeway and NOA is doing its thing. If you transition to a non-NOA road the single blue line will split back into the normal blue "lane lines".
Basically, what it comes down to is:
1. NOA is only available when you have entered a trip destination into the nav system
and the trip includes at least one segment that the car considers a true divided, controlled, highway (no lights etc). In this case, the Blue NOA button will appear just under the navigate to box on the map (and will be on by default).
2. If, during the trip, you engage Autosteer when the car is
not in a suitable segment for NOA, you will get the normal blue lane Ines, and NOA will not engage.
3. If, however, you engage Autosteer when the car
is in a suitable segment, you will get the single blue line and NOA will engage.
4. If NOA is engaged and you exit the suitable segment, NOA will disengage and revert to plain Autosteer (you will also be warned of this).
5. You can also manually disengage NOA and switch back to plain Autosteer by tapping the blue NOA button on the map.
Note: Pay close attention to the restrictions and recommendations in the manual about where Autosteer can be used safely, and its limitations.
