The metal disk on the charge port door is corroded in the lower corner and the car is no longer recognizing a closed door. Normally I'd ignore this since the door still closes but it results in the alert appearing to the left of the instrument cluster instead of the navigation. I have a 2013 85D with 85k miles thus out of warranty. A few questions:
- Is the disk magnetized? Has anyone found a replacement (either from Tesla or independent)?
- Has anyone tried a simple solution like metallic tape to cover the corroded area and complete the circuit?
- What was the cost for service to do a repair (I assume they'd replace the entire door, not just the disk and not just the charge port assembly but please correct me if I'm wrong)?
