Thank you, crisis averted, I noticed a clacking just below the drivers side pillar, opened the frunk and theres a plastic guard that covers the inner part of the frunk hinge and holds the 'washer top up cover' in place. It was loose and the wiper arm was knocking it and sending the vibration into the brake pedal. Clicked it all back into place. Mystery solved, hope this helps someone.Been on this forum aa long time and this is definitely a first for me. never seen anything like that reported
Goes without saying there is no physical connectivity between the brakes and wipers so it sounds like an electrical issue.
What year is your car (is it within the standard warranty period)? If so I would think all those will be covered. We had our rear light clusters replaced under warranty for condensation issues. Boot gap shouldn’t be a big issue for them to adjust. Not heard people routinely complaining about condensation in headlights but should be a warranty item.Some more questions if thats okay.
Will Tesla sort these issues under warranty?
1) Condensation in rear lights
2) Boot panel gap
3) Condensation in head light
“If it’s bad enough”Some more questions if thats okay.
2) Boot panel gap
Its in standard warranty until December. Thank youWhat year is your car (is it within the standard warranty period)? If so I would think all those will be covered. We had our rear light clusters replaced under warranty for condensation issues. Boot gap shouldn’t be a big issue for them to adjust. Not heard people routinely complaining about condensation in headlights but should be a warranty item.
Thanks, its pretty bad, my newer beijing build is showing no condensation in either headlights or tail lights in the same conditions.“If it’s bad enough”
Obviously it’s Tesla’s judgement which may not match your own! Some condensation that comes and goes depending on weather seems to be regarded as acceptable these days but if it builds up over time and you end up with a permanent pool at the bottom of the light fitting that should be replaced.
So turns out there WAS physical connectivity between the wipers and brakes then. who knewThank you, crisis averted, I noticed a clacking just below the drivers side pillar, opened the frunk and theres a plastic guard that covers the inner part of the frunk hinge and holds the 'washer top up cover' in place. It was loose and the wiper arm was knocking it and sending the vibration into the brake pedal. Clicked it all back into place. Mystery solved, hope this helps someone.
Hey, just remember ... you're driving a "classic"! Built by actual Americans (probably some of the same Americans that love to bash Chinese made goods in Youtube comments!)Thanks, its pretty bad, my newer beijing build is showing no condensation in either headlights or tail lights in the same conditions.
To be fair (and to try to ruin your joke) I always assumed the condensation problem was a design issue which they fixed before the MiC cars arrived rather than a build issue but I have no evidence to back that up.Hey, just remember ... you're driving a "classic"! Built by actual Americans (probably some of the same Americans that love to bash Chinese made goods in Youtube comments!)
I've done this, it works well.If you have no success getting the rear lights replaced there’s a good YouTube on how to re-seal them yourself.
Take photos of the headlight condensation. If it's like mine in the cold weather it was bad enough to run down the plastic cover making it look like zebra stripes on the snow. I originally complained 3 years ago but I didn't take photos. They said it was normal. A couple of months before my warranty ran out I took photos and asked for a service. They replaced them without any comment. Same process for the rear. Good luckSome more questions if thats okay.
2) Boot panel gap
Had mine replaced THREE times. Still not truly fixed.1) Condensation in rear lights
Thanks, it seems a very common issue, even on low mileage vehicles, it supposedly happens when the grease in the ball joint dries up / leaks, but its a 1 piece component so they replace the entire arm. From what I have researched Tesla made a revised part but not much better. Temp fix is to inject more grease into the ball joint and rotate the pin.Had no4 replaced twice. The sound is exactly as you describe.
