Are your weights for the 8.5" fronts or the 10" rears? Or the average of the two?
Dont forget to add the increased tire weight to your calculations of reduced unsprung weight...245-285 are heavier than 235's
Thanks so much for your business. Looking forward to seeing mounted photos.Jimmy is super patient and knowledgeable. Pull the trigger on Signature SV503 in 19inch, thx again!
Like for like, Pilot sport 4s (oe 20" tires)
235/45R18 = 23lbs
245/40R19 = 24lbs
255/35R19 = 24lbs
275/35R19 = 27lbs
285/35R19 = 28lbs
235/35R20 = 24lbs (TO Spec)
245/35R20 = 24lbs (non TO)
255/30R20 = 23lbs
275/30R20 = 28lbs (TO SPec)
285/30R20 = 27lbs (non TO)
Conti Procontact RX (OE 19" tires)
235/40r19 =23lbs
245/40r19 =25lbs
275/35r19 = 28lbs
No other available sizes
Michelin Primacy mxm4 (oe 18's)
235/45r18 = 25lbs
245/45r18 = 27lbs
275/40/18 = N/A
245/40r19 = 29lbs
275/35R19 = N/A
OE 18" tires 25lbs
OE19" tires 23lbs
OE 20" tires 24lbs
Reasonably reduce your claimed sprung weight reductions by 40lbs-60lbs (depending on tire) for a common 245/275 staggered (assuming your quoted weights are for the average of an 8.5" wheel and 10" wheel and not the lesser of the two).
Food for thought, the 0-60 time of the performance with no passengers and 2 passengers is identical (from a dig, my P3D+ vs my boss's P3D-, him vs me both solo and him vs me with 2 passengers yields identical results). Car is traction limited. More people =>ukN, means it can feed more power in before impending slip is achieved. All that lighter wheels/tires do to the 3 is change your damping profile as the dampers are tuned for a specific wheel/tire/suspension mass. You also end up with much noisier tires as I found. The TO spec tires are significantly quieter albeit slightly heavier.
Totally an aesthetics purchase! That said I sold my 20's and bought aftermarket 19's. Were your SV104's available at the time I probably would have grabbed those instead of what I ended up with. Great wheel selections!
A big bonus that these can accomodate OEM center cap. Do these wheels also have relief pockets for the protruding rotor bolt?
Signature had a customer changed his mind and switch to 20s instead, so i got his ready ones 3 weeks ahead of schedule. Now i wait for UPS...... waiting waiting waiting
SV503 Brushed Black Triple Tint
19x9.5 ET34 Square
Can't wait to see these on! What are they going on? RWD, AWD, P-AWD?
I am thinking about a square setup 19x9.5 +35 in SV104 and also getting the sport MPP suspension. I have the performance model but without the need for the hub lip since mine did not come with the performance brakes nor the thin rotors. There seems to be plenty of inner clearance in the front if MPP is running 19x10 +35 so wondering why you chose +34 for offset rather than +35? The wheel already pokes a bit at +35.Sweet. Thanks for the correction. We'll document that setup as well, doing 19x9.5 ET34 for our personal vehicle with MPP suspension. Thanks guys.
The back story is interesting but I guess my question was to see what offset would be optimum for my specific setup and goal:It was a set that we already built for a customer that changed to a 20" setup. Since he'll be running MPP Comfort Coilovers at the lowest setting (before the need to change out the Toe arms), that natural camber pulls the top of the wheels in to create a flush setup. 35 vs 34 is 1mm, a human eye cannot notice that insignificant difference on a car without precise measuring tools.
Most manufacturers round offsets to the nearest 5mm due to ease of casting or inventory management. Our wheels are custom built to the customer's suspension, tire size, tire width, and desired need. We have the ability to fine tune in 1mm increments for a well tailored fitment.
Setup:
- SV104 19x9.5 square with 265/35 Michelin Pilot Sport A/S 3+ tires
- P3D- without the thin rotors, without hub lip (3mm I think)
- MPP sport coil-overs lowered only one inch (minimum lower for good rebound).
- MPP 365 big brake rotor kit
Goal:
1. absolutely no rubbing under any situation
2. least amount of poke after first goal is met
What would the weight of SV104 in 19x9.5 be?
