SBD47
They are Signature SV602s, 20x9.5.What brand and spec are your wheels?
They likely came from a different platform or just like softer rides in general. It is a Road & Track kit, not a street comfort kit. For those looking for street comfort, Swift springs of lower rates can be used.All these comments of R/T kit being too stiff is making me nervous. I get mine installed next month. I’m hoping it will be like My Evo X Ohlins setup. I ended up getting stiffer Swift springs..I believe it was 10k front and like 11 rear, stiffer than OEM but I loved the ride and it was a daily. I hope I don’t have to change anything out.
My Evo X setup. Ohlins/Swift/Vorshlag camber top hats
Did going from 11k to 10k make a noticeable difference?Edit: got 10k springs for the rears to stay within 20% of standard spring rates from ohlins
I haven’t installed the 10k springs yet. During the past week I’ve been debating whether I should install them because I drove my friend’s car with standard 11k/12k springs and I don’t think there’s a huge difference to my car, especially the rear end.Did going from 11k to 10k make a noticeable difference?
It sounds like you notice more of a difference in the front with the 3k difference in spring rate versus the rear, which only has a 1k difference, which makes sense. If you feel like another 1k drop isn't going to make much difference, maybe going to 9k rear would be more worthwhile?I haven’t installed the 10k springs yet. During the past week I’ve been debating whether I should install them because I drove my friend’s car with standard 11k/12k springs and I don’t think there’s a huge difference to my car, especially the rear end.
As I stated why I didn’t go for 9k springs, I didn’t want to go beyond 20% softer springs without revalving the shocks. I don’t mind the stiffness, the reason I wanted to lower the rear spring rates is because I felt the rears being noticeably stiffer than the fronts. As I’m getting used to the coilovers, guess what, I don’t feel it that way anymore lol.It sounds like you notice more of a difference in the front with the 3k difference in spring rate versus the rear, which only has a 1k difference, which makes sense. If you feel like another 1k drop isn't going to make much difference, maybe going to 9k rear would be more worthwhile?
I swear my Redwood Ohlins got smoother as they wore in over the first couple hundred miles or even couple thousand miles. Like there was stiction when brand new which is gone now. Maybe I just got used to them but I think it's more than that. At first they felt firmer over small stuff than I expected (based on experiencing Ohlins DFV in a Polestar 2 Performance). Now they're every bit as smooth as I'd hoped given that it's the "Performance Sport" version (not the soft GT kit).As I stated why I didn’t go for 9k springs, I didn’t want to go beyond 20% softer springs without revalving the shocks. I don’t mind the stiffness, the reason I wanted to lower the rear spring rates is because I felt the rears being noticeably stiffer than the fronts. As I’m getting used to the coilovers, guess what, I don’t feel it that way anymore lol.
With these softer springs and the dampers at full soft, is there still less body roll and better control of the car then stock? What setting are you typically keeping the dampers now for street use?Ride quality improved significantly, with little to no distinguishable difference in the vehicle's level of stability. Naturally on a track or for really aggressive street driving (on good roads), the standard 11/12K Ohlins springs would prevail, but the softer 8/9K Swift springs IMO offer a much more balanced level of performance and comfort for everyday street use. I also found that the dampening adjustments with the softer Swift springs are much more prevalent, and the 20 click range offered by the R&T kit is adequate to keep the car street friendly, while still offering a respectful level of "track-ability" at the firmer end of the adjustments.
You can go 30% according to Ohlins USA.As I stated why I didn’t go for 9k springs, I didn’t want to go beyond 20% softer springs without revalving the shocks. I don’t mind the stiffness, the reason I wanted to lower the rear spring rates is because I felt the rears being noticeably stiffer than the fronts. As I’m getting used to the coilovers, guess what, I don’t feel it that way anymore lol.
I’d rather stay as close to standard as possible. Yes in theory I might be able to go 30% either way but by doing that I lose useable adjustments on the shocks. Now I’m getting used to the rear spring rates I don’t see the need to go softer. Considering redwood performance and mpp sport spring rates are about the same as what I’m running right now, changing the rear springs might not be the best idea for optimum handling either.You can go 30% according to Ohlins USA.
That must have been some big dip!On a big dip at speed, I did manage to hit the bump stops for the first time. Oops! Happy with my RT springs.
It is. And I was going seriously fast.That must have been some big dip!
