Is it because you lower the chassis too far? Thats why its bottom out? Hows the ride now after a few weeks? My stock spring 11/12k still rock hard even on 20 clicks all round. Ordered 8/9k, still waiting for deliveryIt is. And I was going seriously fast.
If your stock springs are rock hard, there's a possibility they weren't installed correctly. Possibly too much pre-load? Have you tried 20 clicks from the opposite direction, in case you are 20 click from full soft instead? I have mine set at 7 clicks from full stiff and they're great!Is it because you lower the chassis too far? Thats why its bottom out? Hows the ride now after a few weeks? My stock spring 11/12k still rock hard even on 20 clicks all round. Ordered 8/9k, still waiting for delivery
I bottomed out because I hit a massive dip at 90mph. Most anything would have bottomed out, certainly everything I own. The car is raised, not lowered. 1" oversized wheels + 20mm lift. I'm sure a Raptor would have been fine.Is it because you lower the chassis too far? Thats why its bottom out? Hows the ride now after a few weeks? My stock spring 11/12k still rock hard even on 20 clicks all round. Ordered 8/9k, still waiting for delivery
Rock hard for some could be soft as a pillow for others. Ride quality is very subjective.If your stock springs are rock hard, there's a possibility they weren't installed correctly. Possibly too much pre-load? Have you tried 20 clicks from the opposite direction, in case you are 20 click from full soft instead? I have mine set at 7 clicks from full stiff and they're great!
I agree, but “Rock Hard” implies that they are VERY stiff at 20 clicks and that hasn’t been my experience. I’ll go as far as to say that if you have these at 20 clicks from full stiff and they are rock hard, something is wrong. These are in no way a “comfort” suspension. They are marketed as Road & Track, so they are going to be on the Sporty side of the spectrum. That being said, they should only be “rock hard” if they are turned all the way stiff.Rock hard for some could be soft as a pillow for others. Ride quality is very subjective.
@Leafable Remember that @Jigglypuff has a Y, and raised it with the coilovers + larger tires. Where he still bottoms out a lowered 3 might feel like it's going airborne.Is it because you lower the chassis too far? Thats why its bottom out? Hows the ride now after a few weeks? My stock spring 11/12k still rock hard even on 20 clicks all round. Ordered 8/9k, still waiting for delivery
I agree. 20 clicks open shouldn't be "rock hard". I think most are reading Road & Track as comfort and have expectation of a soft ride.I agree, but “Rock Hard” implies that they are VERY stiff at 20 clicks and that hasn’t been my experience. I’ll go as far as to say that if you have these at 20 clicks from full stiff and they are rock hard, something is wrong. These are in no way a “comfort” suspension. They are marketed as Road & Track, so they are going to be on the Sporty side of the spectrum. That being said, they should only be “rock hard” if they are turned all the way stiff.
Nothing wrong with putting stock rate springs on the Ohlins. Redwood will gladly sell them to you.Sorry guys, my "Rock Hard" might had been over exaggerated. Even though it stiff I still love the Ohlins kits without any regret. The handling improved 1000% compare to stock even at 20 clicks away from stiff. It's just give me a big grin on every drive. Where it can improve is some of the high sharp bump can be less hard/stiff. Where we live the road ain't good with lots of potholes and I feel sorry for my passengers get the hard bump and bounce, still not as bad as the stock with the second bounce eventhough its slightly softer. Ohlins damper just stop the bump in 1 stop instead of multiple bounce. I probably expecting and thinking this is more for street but as the name suggesting track.
Stock is 7k rear not sure about the front. 7k might be a bit too soft I think might be wobbly around like a boat.Nothing wrong with putting stock rate springs on the Ohlins. Redwood will gladly sell them to you.
Nearly 1 lb lighter and a lot more stroke.Not a huge difference in springs of the same stiffness and length.
The stock springs don't make the Model Y wobble. It's the awful damping that allows the car to wobble. GT kits have about stock spring rates.Stock is 7k rear not sure about the front. 7k might be a bit too soft I think might be wobbly around like a boat.
1lb in the spring isn't going to matter much compared to the weight of everything else. I'm not sure how much more stroke we're talking. Half an inch at full compression?Nearly 1 lb lighter and a lot more stroke.
Just good to know it's there when you need it.The stock springs don't make the Model Y wobble. It's the awful damping that allows the car to wobble. GT kits have about stock spring rates.
