I decided to swap the standard sport 11/12K springs that came with the Ohlins R&T coilover kit on my M3P for a set of softer 8/9K Swift springs.
I (and the fam) found the Ohlins springs to be a little too aggressive for daily street use, which even in the softest damping settings resulted in a little more suspension feedback than what I (we) wanted. Now I knew going into the R&T kit, the ride would be firmer than stock, but after a week or so behind the wheel, it was evident the kit was far more track oriented than street. After consulting with the guys over at Ohlins, Swift, and a few others in the industry, it was clear one of the key differences between most sport and street oriented coilover setups was that the street, aka comfort or GT kits, had 20-25% softer springs than their sport counterpart. So with that info on hand, I decided to swap in a set of speced 8/9K Swift springs and let me tell you something - I couldn't be happier with the results!
Ride quality improved significantly, with little to no distinguishable difference in the vehicle's level of stability. Naturally on a track or for really aggressive street driving (on good roads), the standard 11/12K Ohlins springs would prevail, but the softer 8/9K Swift springs IMO offer a much more balanced level of performance and comfort for everyday street use. I also found that the dampening adjustments with the softer Swift springs are much more prevalent, and the 20 click range offered by the R&T kit is adequate to keep the car street friendly, while still offering a respectful level of "track-ability" at the firmer end of the adjustments.
Installation and setup was straightforward and this time around, I had all four corners swapped and ready to go in just an hour and a half. The softer springs also allow for more of drop than with the firmer standard Ohlin springs, so I was able to go a little lower with the suspension. The car is currently sitting right around 30mm lower than stock (I had it at 25mm prior), which definitely closed up the monstrous wheel gaps the Model 3 is infamous for. Erring on the side caution, and to make the ride height a little more street friendly, I may ultimately bump up the suspension a bit. I will also see how it all fares after I get it aligned again later this week.
So although the R&T kit took a little fine tuning, and additional resources, it is now IMO a far more balanced road & track setup. I am aware there are other kits out there that would have sufficed in what I was looking for (and cost less) but having ridden all sorts of motorcycles for the past 40+ years, many of which with Ohlins suspension components, I knew if I went with anything other than Ohlins, I would have always second guess and or regret my purchase. Everything I have ever owned that utilized Ohlins suspension in one way or the other, has always performed beyond my expectations, and I'm happy to report, that is still the case.
The whole Ohlins R&T setup with the Swift springs set me back right around $3600. It’s not for everyone, but if you absolutely want nothing less than the best, it's a small price to pay. I was also pleasantly surprised that the Swift springs I sourced from Redwood Motorsports came painted in the identical yellow color as that of the Ohlins springs!
Here are the part numbers for the 8/9K Swift Springs, which are sold in pairs.
Front: Z65-203-080 (8 kgf/mm - 448 lbs/inch)
Rear: Z65-178-090 (9 kgf/mm - 504 lbs/inch)
Thank you to everyone at European Auto Source (EAS), Redwood Motorsports, Ohlins USA, and Swift Springs in assisting me with all this.
